iMX6 sabre board MfgTool2 not working.
Question asked by sudhir dumbhare on Aug 10, 2014
Trying to flash iMX6 sabre board by using MfgTool2(with fresh SD card), but it is not working, Am refering "Manufacturing Tool V2 Quick Start Guide",IMX6SABREINFOQSG.pdf document. MfgTool2 is stop after "ModuleID[2] LevelID[10]: ExecuteCommand--Push[WndIndex:0], Body is $ mknod block,mmcblk0,/dev/mmcblk0,block ModuleID[2] LevelID[1]: PortMgrDlg(0)--MSCDevice--Command Push(no file) excute failed" Any help is appreciable. Thanks in advanced.
1) MfgTool version : Mfgtools-Rel-13.01.00_ER_MX6Q_UPDATER.
2) Attached is mfgtool2 cfg,UIcfg & mfgtool log.
Original Attachment has been moved to: MfgTool.log.zip
Original Attachment has been moved to: UICfg.ini.zip
Original Attachment has been moved to: cfg.ini.zip
