Can protocol communication using busmaster with maq
Question asked by prasad rao on Aug 8, 2014
Latest reply on Aug 12, 2014 by prasad rao
Hello All,
I am trying to communicate with busmasetr and k70 using can protocol with mqx but it's not working.
Busmaster coniniously sending the messages but i can not receive it.
the function   result = FLEXCAN_Rx_message(CAN_DEVICE, RX_mailbox_num, &ID, format, &DLC, &dptr, interrupt);  returning the no messages in the buffer.
please find the below code , any modifications  required please suggest me.
Actually iam knew to mqx and can protocol.
#include<stdio.h>
#include <mqx.h>
#include <bsp.h>
#include <lwevent.h>
#include "test.h"
#ifndef PSP_MQX_CPU_IS_KINETIS
#include <flexcan.h>
#endif
#if ! BSPCFG_ENABLE_IO_SUBSYSTEM
#error This application requires BSPCFG_ENABLE_IO_SUBSYSTEM defined non-zero in user_config.h. Please recompile BSP with this option.
#endif
#ifndef BSP_DEFAULT_IO_CHANNEL_DEFINED
#error This application requires BSP_DEFAULT_IO_CHANNEL to be not NULL. Please set corresponding BSPCFG_ENABLE_TTYx to non-zero in user_config.h and recompile BSP with this option.
#endif
LWEVENT_STRUCT event;
/* Task template list */
TASK_TEMPLATE_STRUCT MQX_template_list[] = {
   { MAIN_TASK, Main_Task, 1000L, 8L, "Main task", MQX_AUTO_START_TASK},
    /*{ TX_TASK, Tx_Task, 1000L, 7L, "TX task", 0, 0, 0},*/
    { RX_TASK, Rx_Task, 1000L, 7L, "RX task", 0, 0, 0},
   { 0L, 0L, 0L, 0L, 0L, 0L }
#if PSP_MQX_CPU_IS_KINETIS
void MY_FLEXCAN_ISR
   /* [IN] FlexCAN base address */
   pointer can_ptr
   volatile CAN_MemMapPtr        can_reg_ptr;
   vuint_32                               tmp_reg;
   vuint_32                               temp;
   can_reg_ptr = (CAN_MemMapPtr)can_ptr;
   /* get the interrupt flag */
   tmp_reg = (can_reg_ptr->IFLAG1 & CAN_IMASK1_BUFLM_MASK);
   // check Tx/Rx interrupt flag and clear the interrupt
   if(tmp_reg){
      /* clear the interrupt and unlock message buffer */
      /* Start CR# 1751 */
      _lwevent_set(&event, tmp_reg);
      can_reg_ptr->IFLAG1 |= tmp_reg;
      /* End CR# 1751 */
      temp = can_reg_ptr->TIMER;
   }/* Endif */
   // Clear all other interrupts in ERRSTAT register (Error, Busoff, Wakeup)
   tmp_reg = can_reg_ptr->ESR1;
   if(tmp_reg & FLEXCAN_ALL_INT){
      can_reg_ptr->ESR1 |= (tmp_reg & FLEXCAN_ALL_INT);
      /* End CR# 1751 */
   } /* Endif */
   return;
#else
void MY_FLEXCAN_ISR
   pointer can_ptr
   volatile FLEXCAN_REG_STRUCT_PTR        can_reg_ptr;
   vuint_32                               tmp_reg;
   vuint_32                               temp;
   can_reg_ptr = (FLEXCAN_REG_STRUCT_PTR)can_ptr;
   tmp_reg = (can_reg_ptr->IFLAG & FLEXCAN_IMASK_VALUE);
   if(tmp_reg){
      can_reg_ptr->IFLAG |= tmp_reg;
      /* End CR# 1751 */
   }/* Endif */
   tmp_reg = can_reg_ptr->ERRSTAT;
      can_reg_ptr->ERRSTAT |= (tmp_reg & FLEXCAN_ALL_INT);
      /* End CR# 1751 */
   } /* Endif */
   return;
#endif
/*TASK*-----------------------------------------------------------
* Task Name : Main_Task
* Comments :
*END*-----------------------------------------------------------*/
void Main_Task(uint_32 parameter)
{ /* Body */
   _task_id     created_task;
   uint_32 result;
   _int_install_unexpected_isr();
   if (_bsp_flexcan_io_init(CAN_DEVICE) != 0)
      printf ("\nError initializing pins for FlexCAN device %d!\n", CAN_DEVICE);
      _task_block();
   printf("\n*********FLEXCAN TEST PROGRAM.*********");
   printf("\n   Message format: Standard (11 bit id)");
   printf("\n   Message buffer 0 used for Tx and Rx.");
   printf("\n   Interrupt Mode: Enabled");
   printf("\n   Operation Mode: TX and RX --> Normal");
   printf("\n***************************************\n");
   frequency = 250;
   printf("\nselected frequency (Kbps) is: %d", frequency);
   data_len_code = 1;
   printf("\nData length: %d", data_len_code);
   /* Select message format */
   format = FLEXCAN_STANDARD;
   /* Select mailbox number */
   //RX_mailbox_num = 0; just for checking purpose.
   RX_mailbox_num = 1;
   TX_mailbox_num = 1;
   RX_remote_mailbox_num = 2;
   TX_remote_mailbox_num = 3;
/*#if NODE==1
   RX_identifier = 0x123;//0x123;
   TX_identifier = 0x321;
   RX_remote_identifier = 0x0F0;
   TX_remote_identifier = 0x00F;
#else
   RX_identifier = 0x321;
   TX_identifier = 0x123;
   RX_remote_identifier = 0x00F;
   TX_remote_identifier = 0x0F0;
#endif   */
   /* We use default settings */
   bit_timing0 = bit_timing1 = 0;
   /* Select operation mode */
   /*flexcan_mode = FLEXCAN_NORMAL_MODE;*/
     flexcan_mode = FLEXCAN_LOOPBK_MODE;
   /* Enable interrupt */
   interrupt = FLEXCAN_ENABLE;
   /* Enable error interrupt */
   flexcan_error_interrupt = 1;
   /* Reset FLEXCAN device */
   result = FLEXCAN_Softreset ( CAN_DEVICE);
   printf("\nFLEXCAN reset. result: 0x%lx", result);
   /* Initialize FLEXCAN device */
   result = FLEXCAN_Initialize ( CAN_DEVICE, bit_timing0, bit_timing1, frequency, FLEXCAN_IPBUS_CLK);
   printf("\nFLEXCAN initilization. result: 0x%lx", result);
    /* Select mode */
   result = FLEXCAN_Select_mode( CAN_DEVICE, flexcan_mode);
   printf("\nFLEXCAN mode selected. result: 0x%lx", result);
   result = FLEXCAN_Set_global_stdmask (CAN_DEVICE, 0x222 );//
   printf("\nFLEXCAN global mask. result: 0x%lx", result);
   /* Enable error interrupts */
   if(flexcan_error_interrupt == 1)
      result = FLEXCAN_Install_isr_err_int( CAN_DEVICE, MY_FLEXCAN_ISR );
      printf("\nFLEXCAN Error ISR install, result: 0x%lx", result);
      result = FLEXCAN_Install_isr_boff_int( CAN_DEVICE,  MY_FLEXCAN_ISR  );
      printf("\nFLEXCAN Bus off ISR install, result: 0x%lx", result);
      result = FLEXCAN_Error_int_enable(CAN_DEVICE);
      printf("\nFLEXCAN error interrupt enable. result: 0x%lx", result);
  /* Set up an event group */
    result = _lwevent_create(&event, LWEVENT_AUTO_CLEAR);
    if (result != MQX_OK) {
        printf("\nCannot create lwevent");
   created_task = _task_create(0, RX_TASK, 0);
   if (created_task == MQX_NULL_TASK_ID)
      printf("\nRx task: task creation failed.");
    /*created_task = _task_create(0, TX_TASK, 0);
      printf("\nTx task: task creation failed.");
   /* Start FLEXCAN */
   result = FLEXCAN_Start(CAN_DEVICE);
   printf("\nFLEXCAN started. result: 0x%lx", result);
   // start the ping pong
   while(1){}
} /* EndBody */
* Task Name : Tx_Task
* Comments :
void Tx_Task(uint_32 parameter)
{/* Body */
   uchar   data = 0;
   uint_32 result;
   uchar string[] =
     0xa, 0xb, 0xe, 0xc, 0xe, 0xd, 0xa, 0x0
   result = FLEXCAN_Initialize_mailbox( CAN_DEVICE, TX_remote_mailbox_num, TX_remote_identifier,
                                        8, FLEXCAN_TX, format,
                                        interrupt);
   printf("\nFLEXCAN tx remote mailbox initialization. result: 0x%lx", result);
   /* Initialize mailbox */
   result = FLEXCAN_Initialize_mailbox( CAN_DEVICE, TX_mailbox_num, TX_identifier,
                                        data_len_code, FLEXCAN_TX, format,
                                        interrupt);
   printf("\nFLEXCAN tx mailbox initialization. result: 0x%lx", result);
   result = FLEXCAN_Activate_mailbox(CAN_DEVICE, TX_mailbox_num, FLEXCAN_TX_MSG_BUFFER_NOT_ACTIVE);
   printf("\nFLEXCAN tx mailbox activation. result: 0x%lx", result);
   /* Install ISR */
   if(interrupt == FLEXCAN_ENABLE)
      result = FLEXCAN_Install_isr( CAN_DEVICE, TX_mailbox_num, MY_FLEXCAN_ISR  );
      printf("\nFLEXCAN TX ISR install. result: 0x%lx", result);
      result = FLEXCAN_Install_isr( CAN_DEVICE, TX_remote_mailbox_num, MY_FLEXCAN_ISR  );
      printf("\nFLEXCAN TX remote ISR install. result: 0x%lx", result);
   /* Let Rx Task start to initialize */
   _time_delay(1000);
   result = FLEXCAN_Tx_message(CAN_DEVICE, TX_mailbox_num, TX_identifier,
                              format, data_len_code, &data);
   if(result != FLEXCAN_OK)
      printf("\nTransmit error. Error Code: 0x%lx", result);
   else
      printf("\nData transmit: %d", data);
   while(1)
      /* Let Rx Task receive message */
      _time_delay(1000);
      data++;
      result = FLEXCAN_Tx_mailbox(CAN_DEVICE, TX_mailbox_num, &data);
      else
      string[7] = data;
      result = FLEXCAN_Update_message(CAN_DEVICE, string, 8, format, TX_remote_mailbox_num);
      printf("\nFLEXCAN tx update message. result: 0x%lx", result);
} /* EndBody */
* Task Name : Rx_Task
* Comments :
void Rx_Task(uint_32 parameter)
{/* Body */
   //uchar   dptr[8];
   uchar   dptr[8] = {0, 0, 0, 0, 0, 0, 0, 0};
   uint_32 result = -1;
   uint_32 DLC = 0;
   uint_32 ID = 0;
  result = FLEXCAN_Initialize_mailbox( CAN_DEVICE, RX_mailbox_num, RX_identifier,
                                       8, FLEXCAN_RX, format,
                                        interrupt);
   printf("\nFLEXCAN rx remote mailbox initialization. result: 0x%lx", result);
  /*result = FLEXCAN_Initialize_mailbox( CAN_DEVICE, RX_mailbox_num, RX_identifier,
                                        data_len_code, FLEXCAN_RX, format,
                                       interrupt);
   printf("\nFLEXCAN rx mailbox initialization. result: 0x%lx", result);*/
   result = FLEXCAN_Activate_mailbox(CAN_DEVICE, RX_mailbox_num, FLEXCAN_RX_MSG_BUFFER_EMPTY);
   printf("\nFLEXCAN mailbox activation. result: 0x%lx", result);
   /* Install ISR */
      result = FLEXCAN_Install_isr( CAN_DEVICE, RX_mailbox_num, MY_FLEXCAN_ISR );
      printf("\nFLEXCAN RX ISR install. result: 0x%lx", result);
      /*result = FLEXCAN_Install_isr( CAN_DEVICE, RX_remote_mailbox_num, MY_FLEXCAN_ISR  );
      printf("\nFLEXCAN RX remote ISR install. result: 0x%lx", result);*/
if (_lwevent_wait_ticks(&event, 1 << RX_mailbox_num, FALSE, 1000) != MQX_OK) {
     printf("\nEvent Wait failed");
  result = FLEXCAN_Lock_mailbox (CAN_DEVICE, RX_mailbox_num);
     printf("\nLock mailbox failed. Error Code: 0x%lx", result);
     printf("\nReceived error. Error Code: 0x%lx", result);
  else
    printf("\nReceived data: ");
    for (result = 0; result < DLC; result++) printf ("0x%x ", dptr[result]);
     printf("\nID is: 0x%x", ID);
     printf("\nDLC is: 0x%x\n", DLC);
  result = FLEXCAN_Unlock_mailbox (CAN_DEVICE);
     printf("\nUnlock mailbox failed. Error Code: 0x%lx", result);
   while(1)
     _time_delay(1000);
           printf("\nReceived error. Error Code: 0x%lx\n", result);
            switch(result)
              case FLEXCAN_MESSAGE_OVERWRITTEN:
                  printf("\nMessage overwritten\n");
                  break;
              case FLEXCAN_INVALID_ADDRESS:
                  printf("\Wrong device Number\n");
                  break;
              case FLEXCAN_INVALID_MAILBOX:
                  printf("\Wrong message box number\n");
                  break;
              case FLEXCAN_NO_MESSAGE:
                  printf("\Mail box is empty\n");
                  break;
              case FLEXCAN_MESSAGE_FORMAT_UNKNOWN:
                  printf("\Wrong msg format\n");
                  break;
      else
      FLEXCAN_Request_message (CAN_DEVICE, RX_remote_mailbox_num, format);
   result = FLEXCAN_Initialize_mailbox( CAN_DEVICE, RX_remote_mailbox_num, RX_remote_identifier,
  interrupt);
} /* EndBody */
/* EOF */
