Reading from Nand Flash in TWRK70F120M
Question asked by Sneha Hegde on Aug 8, 2014
Latest reply on Aug 11, 2014 by Sneha Hegde
Hi Team,
I have a set of below parameters which I am saving into the respective blocks:
Parameter1  : Block 0
Parameter 2: Block 1 to Block 6
Parameter 3: Block 111
Parameter 4: Block 156 into Block 161
The problem I am facing here is that only when I save the parameters starting from the 4th to 1st, I am able to read them correctly on start up, else it fails to read the parameters. Please suggest the probable reason and the way this problem could be solved.
Thanks and Regards,
Sneha Hegde
