As KDS V1.1.0 release notes said:
Support for additional downloadable Eclipse plug-ins including RTOS-awareness (including MQX™ and FreeRTOS)
But I can't find the method or manul to install this plug in.
Anyone could help on this ?
Thanks!
Solved! Go to Solution.
The FreeRTOS plugin is available from HighIntegritySystems, see DIY Free Toolchain for Kinetis: Part 5 – FreeRTOS Eclipse Kernel Awareness with GDB | MCU on Eclipse
The MQX plugin will be available later today with the normal Eclipse updater mechanism.
Menu Help > Install New Software, then select
Freescale KDS Update Site - http://freescale.com/lgfiles/updates/Eclipse/KDS
update site
(again, it is not there yet, but will be later today).
Erich
update site
Erich
The Freescale KDS update site is now live!
yes, MQX aware is working on KDS 1.1.0.
See:
