Processor Expert compiling errors
Question asked by Mingzhao Li on Aug 4, 2014
Latest reply on Aug 13, 2014 by ZhangJennie
Hi guys,
Recently i am trying to use Processor Expert to generate codes for PWM on K70F120.
However, after I generated the codes, some errors occurred after compiling.
Errors:
DescriptionLocationResourcePathType
mingw32-make: *** [Generated_Code/Cpu_c.obj] Error 1bsp_twrk70f120mC/C++ Problem
mingw32-make: *** [Sources/Events_c.obj] Error 1bsp_twrk70f120mC/C++ Problem
mingw32-make: *** Waiting for unfinished jobs....bsp_twrk70f120mC/C++ Problem
my events.c:
void PWM_OnCounterRestart(LDD_TUserData *UserDataPtr)
  /* Write your code here ... */
PWM_SetPeriodTicks();
PWM_ResetCounter();
PWM_GetCounterValue();
PWM_SetOffsetTicks();
PWM_GetCaptureValue();
PWM_Init();
**     Event       :  Cpu_OnLLSWakeUpINT (module Events)
**     Component   :  Cpu [MK70FN1M0MJ15]
**     @brief
**         This event is called when Low Leakage WakeUp interrupt
**         occurs. LLWU flags indicating source of the wakeup can be
**         obtained by calling the [GetLLSWakeUpFlags] method. Flags
**         indicating the external pin wakeup source are automatically
**         cleared after this event is executed. It is responsibility
**         of user to clear flags corresponding to internal modules.
**         This event is automatically enabled when [LLWU interrupt
**         request] is enabled.
void Cpu_OnLLSWakeUpINT(void)
  Cpu_DisableInt();
/* END Events */
#ifdef __cplusplus
}  /* extern "C" */
#endif
