Hi all,
I'm trying to enable Dlib multi-thread support in IAR workbench while using MQX. It requires some redirects for locks etc. I can't for the life of me work out how/which functions to redirect. There is some documentation, but I'll be honest and admit that I don't fully understand it.
Anyone done this already? It seems like something that everyone using MQX with IAR would have to do.
Cheers in advance,
BillND
Solved! Go to Solution.
Hi BillND,
Please check the below link.
http://supp.iar.com/Support/?Note=95292
Could you please share with us a little bit more information about the application that you need to develop?
In order to use IAR and MQX you can check the Getting Started with Freescale MQX™ RTOS and IAR Embedded Workbench® . This document describes the steps required to configure the IAR Embedded Workbench® development tools and use it to build, run, and debug applications of the Freescale MQX™ RTOS operating system.
You can find this document after install MQX at the next path: C:\Freescale\Freescale_MQX_4_1\doc\tools\iar
Sol
Hi BillND,
Sol
