K60 UART DMA using PE not working !
Question asked by Amit Kumar on Jul 31, 2014
Latest reply on Aug 1, 2014 by Mark Butcher
I am using codewarrior 10.5 , 10.6 . I wanted to make a simple program in which I will send a char through terminal window  using DMA for receiving, I will store that in a variable and will echo that back. I had to send a string but initially I tried with a char. The DMA didn't worked. Attached is the codes I made 2 code sto test using DMAT, DMACH component of PE. Currently I am using MK60512VLL10 uc. and DMA is configured to UART4 Receive. I have made it worked using DMAT component in K20. It works fine there, I have transmitted 100 bytes using DMA in K20. but in K60 I am not able to .I checked in CW10.5 as well as CW10.6 but it didn't worked Please look into the matter.
Kind Regards
Amit Kumar
Original Attachment has been moved to: DMA-TEST-DMAT.zip
Original Attachment has been moved to: DMA-TEST-DMACH.zip
