Print settings
Print settings
pascalschröer
Contributor V
Hi at all,
Can anyone tell me, how to set up some print settings in CW10.6?? I would like
to set up the distance between the code and the page borders... The "normal"
printer settings don't have options like that.
Thanks!
Pascal
pascalschröer
Contributor V
Now, I have solved the problem! There isn't an option to set up the side clearance, so you have to
scale down the printed window!
Pascal
catalindemergia
After File->Print, select your printer and then hit the Preferences button,
you will find all the settings there.
regards,
Catalin
pascalschröer
Contributor V
Hey,
Ok I have seen this settings but I can't set up the side clearance... Do you know
a solution for this problem?
Thanks!
Pascal
pascalschröer
Contributor V
Pascal
