When will MQX support QSPI1 on Vybrid? Are there issues that prevent cloning the QSPI0 support to support QSPI1?
Nancy
Solved! Go to Solution.
Hi RadekS,
I found the problem:we use a tailored MQX 4.1 and QSPI1 was edited out. When I looked at my local MQX 4.1 installation I see the missing support.
Now to add it back to our official version.
Thank you for your help.
Nancy
Hi Nancy,
there should not be any issue with QSPI1.
QSPI driver include low level driver supports QSPI1.
twrvf65gs10 contains two Flash chips connected to QSPI0_A and QSPI0_B.
vybrid_autoevb contains three Flash chips connected to QSPI0_A, QSPI0_B and QSPI1.
Do you know about any specific issue with QSPI1?
RadekS
Hi RadekS,
Nancy
Thank you for your clarification.
Now it make sense.
