K60 SPI writeread function?
Question asked by Amit Kumar on Jul 27, 2014
Latest reply on Jul 29, 2014 by Kerry Zhou
I was trying to configure SPI based sensor with K60 using Codewarrior 10.6. I am facing problem in reading the data. I was looking for some code for reading the register. I tried using PE components of SPI with DMA. using these components I am able to read 6 registers . The problem I am facing is all the 6 received values are not coming in order to the defined buffer. So I wanted to go with baremetal code. I tried using the example code for SPI but that didn't worked. Please look into the matter. and provide some simple code for readwrite. Thanks in advance
Kind Regards,
Amit Kumar
