delete
delete
Kratz
adriancano
Are you still facing the same issues in your project? I hope that now everything is working correctly.
Please let me know your results.
Adrian
BlackNight
could you post some code snippets? It looks like the compiler is missing the declaration (header file) of that Sens1.
What is Sens1 in your project? But it seems that you might simply not use the correct C syntax?
