mc9s08dz128 flash programming and watchdog
martinlockner
I am trying to use the Processor Expert generated code for flash programming (IFsh1.c and IFsh1.h) and I need a way to feed the watchdog timer while the flash is being programmed. Has anyone come up with a solution for this? I am trying to update some constant tables not program code.
ZhangJennie
Hi Martin,
please refer watchdog sample code attached, you can also find this sample under CW6.3 install folder.
Hope this helps!
this answer is for you, if it helps, please click on "correct answer" button. thanks!
ZhangJun
martinlockner
Jennie,
Thanks for your reply. I might not have made myself clear in my post. I have the watchdog working correctly in my normal firmware operation what my problem is is how to feed the watchdog when I am trying to write to an area of flash memory. I am using Processor Expert and it has generated tow files IFsh1.c and IFsh1.h which contain the methods for writing to flash and what I was trying to find out was where to feed the Watchdog when writing a block to flash.
Marty Lockner
