Unable to Read from Nand Flash in TWRK70f120M
Question asked by Sneha Hegde on Jul 7, 2014
Latest reply on Jul 9, 2014 by Carlos_Musich
Hi Team,
PFB the code for Reading some of the parameters from Flash:
CWasherFormula *pPumpAMount=NULL;
    //for(BYTE byWasherId=0; byWasherId<MAX_WASHERS;byWasherId++)
      //Location=0;
      //byBlockNum=(MAX_WASHERS*2)MAX_PUMPS1+byWasherId;
      pPumpAMount=m_argpDataMgr->GetWasherFormulaPtr(0);
      if(NULL!=pPumpAMount)
        Location=(m_dwNumOfVirtPagesPerBlock*(76));
        fseek(mpFlashPtr, Location, IO_SEEK_SET);
        if(sizeof(CWasherFormula)==read(mpFlashPtr,pPumpAMount,sizeof(CWasherFormula)))
          m_argpDataMgr->SetWasherFormulaConfig(0,pPumpAMount);
          printf("Check ");
I have written the parameters into 76th block of Flash and reading it from the same block. But I find that the control doesn't get into the if block, which is why I am unable to set the data that is read. Kindly let me know how the issue can be resolved.
Thanks and Regards,
Sneha Hegde
