Is there a equivalent version of standalone kinetis controllers that we could use in codewarrior?
If i understand correctly controller and wireless transceiver are interconnected on chip thru SPI, so it should be no problem with workaround like this (only if peripherals etc. are on same locations)..
IAR is the preferred tool for the Kinetis W family. CodeWarrior will not support it.
The stand-alone Processor Expert will supports Kinetis W family.
:smileysad::smileyangry:
