Problem with K60 MCU UART interrupt mode Typical Usage code
Question asked by dkarthik on Jul 1, 2014
Latest reply on Jul 2, 2014 by dkarthik
I'm trying to learn K60 MCU UART using Typical usage of Processor expert component. I added Serial_LDD component and set to UART5 for communication to PC via debugger in TWRK60D100M kit. I used the exact code as in Typical usage. UART for polling mode works but Interrupt mode doesn't work. (I enabled interrupt in Serial Component)
Is there any other interrupts in the processor that should be enabled or Should I be including something in the code to enable additional interrupts. Please help.
