What are the proper steps to initialize and use I2C using the InternalI2C component?
tomii
I've been having no luck getting I2C to work with my FRDM-KE02Z board..  I'm using the KDS 1.0.1 IDE and attempting to use the built-in component library, but I am obviously doing something wrong.  I've enabled the devices and chose the appropriate slave, but every time I try to read/write data, I get an error (ERR_DISABLED)...  It would seem that maybe I'm not correctly enabling turning the I2C hardware.  a code snippet is below, "Accelerometer" is an "InternalI2C" component.
  Accelerometer_Init();
  error = Accelerometer_Enable();            //    enable the accelerometer
  printf("Err:%3d \r\n", error);
  error = Accelerometer_SelectSlave(0x1D);    //    accelerometer address is 0x1D
  error = Accelerometer_SendChar(0x40);        //    reset the accelerometer
//  while( 1 )
      error = Accelerometer_SendChar(0x00);                    //    Send start address
      error = Accelerometer_RecvBlock(AData, 7, &bytes);    //    read back 7 bytes
      error = Accelerometer_RecvChar(&bytes);
      status = AData[0];
//      xG = (AData[1]<<8) + AData[2];
//      yG = (AData[3]<<8) + AData[4];
//      zG = (AData[5]<<8) + AData[6];
      xG = AData[1];
      yG = AData[3];
      zG = AData[5];
      printf("Err:%3d BytesRX:%3d Status:%3d X:%6d Y:%6d Z:%6d\r\n", error, bytes, status, xG, yG, zG);
Tags (4)
