The error message appears as follows
Error log
user@Ubuntu-TSG-Test:~/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release$ ../bitbake/bin/bitbake fsl-image-minimal
WARNING: Bitbake has not been run using the bitbake wrapper (scripts/bitbake); this is likely because your PATH has been altered from that normally set up by the oe-init-build-env script. Not using the wrapper may result in failures during package installation, so it is highly recommended that you set your PATH back so that the wrapper script is being executed.
WARNING: Pseudo is not functioning correctly, which will cause failures during package installation. Please check your configuration.
Loading cache: 100% |###################################################################################################################################| ETA: 00:00:00
Loaded 1769 entries from dependency cache.
Build Configuration:
BB_VERSION = "1.18.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "Ubuntu-12.04"
TARGET_SYS = "powerpc-fsl_networking-linux"
MACHINE = "p2041rdb"
DISTRO = "fsl-networking"
DISTRO_VERSION = "1.4.1"
TUNE_FEATURES = "m32 fpu-hard ppce500mc"
TARGET_FPU = "hard"
meta
meta-yocto
meta-yocto-bsp = "dylan:13be5eeb14211212b27deaaa602bf7006c76b43c"
meta-fsl-ppc = "dylan-sdk1.5:a10a68b4c50efcca9e3740f08dd7c5716ef97ac0"
meta-fsl-ppc-toolchain = "master:813d88970a4357410af833c24910d8371c5206bb"
meta-fsl-networking = "dylan-sdk1.5:729a6be8778f9a9577bc233990dc4a617624640d"
meta-virtualization = "master:0c26da86404a5421f579188d24864aea05c9611a"
meta-oe
meta-networking = "dylan:8c5e175603b0163d57e94216088b9acc203f3a73"
NOTE: Resolving any missing task queue dependencies
NOTE: Preparing runqueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: Function failed: do_configure (see /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/work/ppce500mc-fsl_networking-linux/eglibc/2.15-r3/temp/log.do_configure.17830 for further information)
ERROR: Logfile of failure stored in: /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/work/ppce500mc-fsl_networking-linux/eglibc/2.15-r3/temp/log.do_configure.17830
Log data follows:
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: SITE files ['endian-big', 'bit-32', 'powerpc-common', 'common-linux', 'common-glibc', 'powerpc32-linux', 'powerpc-linux', 'common']
| DEBUG: Executing shell function autotools_preconfigure
| DEBUG: Shell function autotools_preconfigure finished
| DEBUG: Executing shell function do_configure
| NOTE: Running /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/work/ppce500mc-fsl_networking-linux/eglibc/2.15-r3/eglibc-2.15/libc/configure --build=x86_64-linux --host=powerpc-fsl_networking-linux --target=powerpc-fsl_networking-linux --prefix=/usr --exec_prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --libexecdir=/usr/lib/eglibc --datadir=/usr/share --sysconfdir=/etc --sharedstatedir=/com --localstatedir=/var --libdir=/usr/lib --includedir=/usr/include --oldincludedir=/usr/include --infodir=/usr/share/info --mandir=/usr/share/man --disable-silent-rules --disable-dependency-tracking --with-libtool-sysroot=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/p2041rdb --enable-kernel=2.6.16 --without-cvs --disable-profile --disable-debug --without-gd --enable-clocale=gnu --enable-add-ons --with-headers=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/p2041rdb/usr/include --without-selinux --enable-obsolete-rpc --with-kconfig=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/bin -with-cpu=e500mc
| checking build system type... x86_64-pc-linux-gnu
| checking host system type... powerpc-fsl_networking-linux-gnu
| checking for powerpc-fsl_networking-linux-gcc... powerpc-fsl_networking-linux-gcc -m32 -mhard-float -mcpu=e500mc --sysroot=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/p2041rdb-tcbootstrap
| checking for suffix of object files... o
| checking whether we are using the GNU C compiler... yes
| checking whether powerpc-fsl_networking-linux-gcc -m32 -mhard-float -mcpu=e500mc --sysroot=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/p2041rdb-tcbootstrap accepts -g... yes
| checking for powerpc-fsl_networking-linux-gcc -m32 -mhard-float -mcpu=e500mc --sysroot=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/p2041rdb-tcbootstrap option to accept ISO C89... none needed
| checking for gcc... gcc
| checking how to run the C preprocessor... powerpc-fsl_networking-linux-gcc -E --sysroot=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/p2041rdb-tcbootstrap -m32 -mhard-float -mcpu=e500mc
| checking whether we are using the GNU C++ compiler... no
| checking whether powerpc-fsl_networking-linux-g++ -m32 -mhard-float -mcpu=e500mc --sysroot=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/p2041rdb-tcbootstrap accepts -g... no
| configure: running configure fragment for add-on libidn
| configure: running configure fragment for add-on nptl
| checking add-on ports for preconfigure fragments... alpha am33 arm hppa m68k mips powerpc tile
| checking for assembler gnu_indirect_function symbol type support... yes
| checking whether .text pseudo-op must be used... yes
| checking for assembler global-symbol directive... .globl
| checking for assembler .type directive prefix... @
| checking sysdep dirs... sysdeps/powerpc/powerpc32/elf sysdeps/powerpc/elf sysdeps/unix/sysv/linux/powerpc/powerpc32/e500mc/fpu sysdeps/powerpc/powerpc32/e500mc/fpu sysdeps/unix/sysv/linux/powerpc/powerpc32/e500mc sysdeps/unix/sysv/linux/powerpc/powerpc32/fpu sysdeps/powerpc/powerpc32/fpu nptl/sysdeps/unix/sysv/linux/powerpc/powerpc32 ports/sysdeps/unix/sysv/linux/powerpc/powerpc32 sysdeps/unix/sysv/linux/powerpc/powerpc32 nptl/sysdeps/unix/sysv/linux/powerpc ports/sysdeps/unix/sysv/linux/powerpc sysdeps/unix/sysv/linux/powerpc sysdeps/ieee754/ldbl-128ibm sysdeps/ieee754/ldbl-opt nptl/sysdeps/unix/sysv/linux nptl/sysdeps/pthread sysdeps/pthread ports/sysdeps/unix/sysv/linux sysdeps/unix/sysv/linux sysdeps/gnu sysdeps/unix/common sysdeps/unix/mman sysdeps/unix/inet nptl/sysdeps/unix/sysv ports/sysdeps/unix/sysv sysdeps/unix/sysv sysdeps/unix/powerpc nptl/sysdeps/unix ports/sysdeps/unix sysdeps/unix sysdeps/posix sysdeps/powerpc/powerpc32/e500mc ports/sysdeps/powerpc/powerpc32 sysdeps/powerpc/powerpc32 sysdeps/wordsize-32 sysdeps/powerpc/fpu nptl/sysdeps/powerpc ports/sysdeps/powerpc sysdeps/powerpc sysdeps/ieee754/dbl-64 sysdeps/ieee754/flt-32 sysdeps/ieee754 sysdeps/generic/elf sysdeps/generic
| checking for a BSD-compatible install... /usr/bin/install -c
| checking whether ln -s works... yes
| checking whether /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/as is GNU as... yes
| checking whether /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/ld is GNU ld... yes
| checking for /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/as... /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/as
| checking version of /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/as... 2.23.1.20121113, ok
| checking for /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/ld... /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/ld
| checking version of /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/ld... 2.23.1.20121113, ok
| checking for pwd... /bin/pwd
| checking for powerpc-fsl_networking-linux-gcc... (cached) powerpc-fsl_networking-linux-gcc -m32 -mhard-float -mcpu=e500mc --sysroot=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/p2041rdb-tcbootstrap
| checking version of powerpc-fsl_networking-linux-gcc -m32 -mhard-float -mcpu=e500mc --sysroot=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/p2041rdb-tcbootstrap... 4.7.3, ok
| checking for gnumake... make
| checking version of make... 4.0, bad
| checking for gnumsgfmt... no
| checking for gmsgfmt... no
| checking for msgfmt... msgfmt
| checking version of msgfmt... 0.18.1, ok
| checking for makeinfo... makeinfo
| checking version of makeinfo... 4.13, ok
| checking for sed... sed
| checking version of sed... 4.2.1, ok
| checking for powerpc-fsl_networking-linux-readelf... powerpc-fsl_networking-linux-readelf
| checking for autoconf... autoconf
| checking whether autoconf works... yes
| configure: error:
| *** These critical programs are missing or too old: make
| *** Check the INSTALL file for required versions.
| Configure failed. The contents of all config.log files follows to aid debugging
| ERROR: oe_runconf failed
ERROR: Task 34 (/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/meta-fsl-ppc-toolchain/recipes-devtools/eglibc/eglibc_2.15.bb, do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 181 tasks of which 180 didn't need to be rerun and 1 failed.
No currently running tasks (181 of 1686)
Summary: 1 task failed:
Summary: There were 2 WARNING messages shown.
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
while reading config.log file its found like this
configure:3459: powerpc-fsl_networking-linux-g++ -m32 -mhard-float -mcpu=e500mc --sysroot=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/p2041rdb-tcbootstrap -c -g conftest.cpp >&5
/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/work/ppce500mc-fsl_networking-linux/eglibc/2.15-r3/eglibc-2.15/libc/configure: line 3461: powerpc-fsl_networking-linux-g++: command not found
configure:3466: $? = 127
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME "GNU C Library"
| #define PACKAGE_TARNAME "glibc"
| #define PACKAGE_VERSION "(see version.h)"
| #define PACKAGE_STRING "GNU C Library (see version.h)"
| #define PACKAGE_BUGREPORT "http://sourceware.org/bugzilla/"
| /* end confdefs.h. */
| int
| main ()
| return 0;
configure:3488: result: no
configure:4149: running configure fragment for add-on libidn
configure:4149: running configure fragment for add-on nptl
configure:4205: checking add-on ports for preconfigure fragments
configure:4212: result:
configure:4301: checking for assembler gnu_indirect_function symbol type support
configure:4317: result: yes
configure:4320: checking whether .text pseudo-op must be used
configure:4330: powerpc-fsl_networking-linux-gcc -m32 -mhard-float -mcpu=e500mc --sysroot=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/p2041rdb-tcbootstrap -c conftest.s 1>&5
configure:4333: $? = 0
configure:4344: result: yes
configure:4348: checking for assembler global-symbol directive
configure:4361: powerpc-fsl_networking-linux-gcc -m32 -mhard-float -mcpu=e500mc --sysroot=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/p2041rdb-tcbootstrap -c conftest.s 1>&5
configure:4364: $? = 0
configure:4372: result: .globl
configure:4385: checking for assembler .type directive prefix
configure:4401: powerpc-fsl_networking-linux-gcc -m32 -mhard-float -mcpu=e500mc --sysroot=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/p2041rdb-tcbootstrap -c conftest.s 1>&5
configure:4404: $? = 0
configure:4412: result: @
configure:4437: checking sysdep dirs
configure:4717: result: sysdeps/generic/elf sysdeps/generic
configure:4796: checking for a BSD-compatible install
configure:4864: result: /usr/bin/install -c
configure:4879: checking whether ln -s works
configure:4883: result: yes
configure:4909: checking whether /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/as is GNU as
configure:4923: result: yes
configure:4928: checking whether /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/ld is GNU ld
configure:4942: result: yes
configure:4952: checking for /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/as
configure:4979: result: /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/as
configure:4994: checking version of /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/as
configure:5004: result: 2.23.1.20121113, ok
configure:5015: checking for /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/ld
configure:5042: result: /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/ld
configure:5057: checking version of /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/libexec/ppce500mc-fsl_networking-linux.gcc-cross-initial/gcc/powerpc-fsl_networking-linux/4.7.3/ld
configure:5067: result: 2.23.1.20121113, ok
configure:5082: checking for pwd
configure:5100: found /bin/pwd
configure:5113: result: /bin/pwd
configure:5134: checking for powerpc-fsl_networking-linux-gcc
configure:5161: result: powerpc-fsl_networking-linux-gcc -m32 -mhard-float -mcpu=e500mc --sysroot=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/p2041rdb-tcbootstrap
configure:5176: checking version of powerpc-fsl_networking-linux-gcc -m32 -mhard-float -mcpu=e500mc --sysroot=/home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/p2041rdb-tcbootstrap
configure:5186: result: 4.7.3, ok
configure:5197: checking for gnumake
configure:5224: result: make
configure:5239: checking version of make
configure:5249: result: 4.0, bad
configure:5261: checking for gnumsgfmt
configure:5291: result: no
configure:5261: checking for gmsgfmt
configure:5261: checking for msgfmt
configure:5277: found /usr/bin/msgfmt
configure:5288: result: msgfmt
configure:5303: checking version of msgfmt
configure:5313: result: 0.18.1, ok
configure:5324: checking for makeinfo
configure:5340: found /usr/bin/makeinfo
configure:5351: result: makeinfo
configure:5366: checking version of makeinfo
configure:5376: result: 4.13, ok
configure:5387: checking for sed
configure:5403: found /bin/sed
configure:5414: result: sed
configure:5429: checking version of sed
configure:5439: result: 4.2.1, ok
configure:5450: checking for powerpc-fsl_networking-linux-readelf
configure:5466: found /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/bin/ppce500mc-fsl_networking-linux/powerpc-fsl_networking-linux-readelf
configure:5477: result: powerpc-fsl_networking-linux-readelf
configure:5544: checking for autoconf
configure:5560: found /home/user/SYNC3000_SDK/yes/QorIQ-SDK-V1.5-20131219-yocto/build_p2041rdb_release/tmp/sysroots/x86_64-linux/usr/bin/autoconf
configure:5571: result: autoconf
configure:5586: checking whether autoconf works
configure:5597: result: yes
configure:5608: error:
does anyone have the same problem ???
Solved!!!
the problem is because of incompatible version of make(4.0) ,solved when make reverted to the version 3.8.2
