Bitshrine 404 error
Bitshrine 404 error
raj27
I'm trying to add the multimedia package "IMX_MMCODEC_3.0.35_4.1.0_BUNDLE_CODA" with imx6sololite,but i'm facing the following errors
Try IMX_MMCODEC-3.0.7-2.tar.gz.md5 from the GPP
http://bitshrine.org/gpp/IMX_MMCODEC-3.0.7-2.tar.gz.md5:
14:41:31 ERROR 404: Not Found.
Try IMX_MMCODEC-3.0.7-2.tar.gz from the GPP
http://bitshrine.org/gpp/IMX_MMCODEC-3.0.7-2.tar.gz:
14:41:32 ERROR 404: Not Found.
Can't get: IMX_MMCODEC-3.0.7-2.tar.gz at ./ltib line 802.
f_prep() returned an error, exiting
traceback:
main:572
Exiting on error or interrupt
Imx6sl supports this multimedia package or not ? Plz suggest to solve this issue...
Labels (2)
raj27
Is Imx6sl supports the vpu or not in Ltib. Because when i'm enabling libfslvpuwrap package in ltib for imx6s platform type,i'm facing the errors as shown above comments.can anyone please help me out of this issue...
Yuri
The i.MX6SL does not incorporate the VPU hardware.
Yuri
Yuri
  Please use instructions of section 2.1.2 (Building Plug-Ins) of "i.MX_6_Series_Ubuntu_Multimedia_User's_Guide.pdf".
Perhaps the  the multimedia packages should be located in /opt/freescale/pkgs
Yuri
raj27
Thanks Yuri for your suggestions and i followed the steps mentioned in that section,they are suggesting
libfslcodec, libfslparser, libfslvpuwrap, gst-fsl-plugins, gst-plugins-gl, fsl-alsa-plugins, and gstreamer-plugins-good package to enable.
And i'm able to build only libfslcodec, libfslparser, gst-fsl-plugins, and fsl-alsa-plugins.And remaining 3 packages i'm not able build successfully.And errors showing for the respective pkgs are as follows:
libfslvpuwrap:
configure: error: lib_vpu is required, consider installing imx-lib
error: Bad exit status from /home/rajesh/ltib_dwnlded_jags/L3.0.35_4.1.0_130816_source/raj/ltib/tmp/rpm-tmp.77402 (%build)
RPM build errors:
Build time for libfslvpuwrap: 4 seconds
Failed building libfslvpuwrap
f_buildrpms() returned an error, exiting
traceback:
main:572
These packages failed to build:
libfslvpuwrap
Build Failed
It is saying it needs lib_vpu pkg but it is not available in the gui.
gst-plugins-gl:
configure: error: GL or EGL is required, consider installing libgl1-mesa-dev
error: Bad exit status from /home/rajesh/ltib_dwnlded_jags/L3.0.35_4.1.0_130816_source/raj/ltib/tmp/rpm-tmp.28847 (%build)
RPM build errors:
Build time for gst-plugins-gl: 13 seconds
Failed building gst-plugins-gl
traceback:
main:572
gst-plugins-gl
Build Failed
gstreamer-plugins-good:
configure: error: in `/home/rajesh/ltib_dwnlded_jags/L3.0.35_4.1.0_130816_source/raj/ltib/rpm/BUILD/gst-plugins-good-0.10.30':
configure: error: C compiler cannot create executables
See `config.log' for more details
error: Bad exit status from /home/rajesh/ltib_dwnlded_jags/L3.0.35_4.1.0_130816_source/raj/ltib/tmp/rpm-tmp.8089 (%build)
RPM build errors:
Build time for gst-plugins-good: 3 seconds
Failed building gst-plugins-good
traceback:
main:572
gst-plugins-good
Build Failed
Plz suggest your inputs to fix these issues.....
raj27
As i'm surfing regarding this issue i found imx-lib is blocking the building of those 3 packages.i want to clean only this pkg and again i want to build this pkg.But in the gui imx-lib is by default selected .How to do this.Plz help me out of this....
