Dear All,
I have a TWRK64F120M board.
But I am NOT able to ping the TWR board.
I doubt on the JUMPER settings.
As per “TWR-K64F120M Tower Module User’s Guide” (TWRK64F120MUG.pdf)
Section 6.15 Ethernet and 1588
Table 5. Ethernet operation jumper settings
TWR-K64 J32 - ON
“ “ J33 - OFF
TWR-SER J2 - 3-4
“ “ J3 - 2-3
“ “ J11 - 9-10 (THESE PINS ARE ABSENT IN J11)
Now,
With DHCP, it doesn’t even obtain an IP address.
I observed that BSP initializes MAC in RMII mode.
May be I am doing something wrong or my understanding is wrong.
So I request to please guide me and correct me if in case I am wrong or missing any crucial step.
I appreciate your help and support.
Thanking you,
Mangesh Edake
Solved! Go to Solution.
Hi Mangesh;
It seems this is a documentation errata, I check on the FSL_MQX_getting_started for RMII configuration, below you will find the instructions and RMII communication mode is enabled on J12 with 9-10 pins connection, please see below:
To enable Ethernet communication (use with TWR-SER):
Have a nice day,
Perla Moncada
Hi Mangesh;
Have a nice day,
Perla Moncada
