I would like someone to please look at this code particularly the portserial files and interrupts to determine what I'm doing wrong. I was finally able to build the code but unable to communicate to it. When I attempt to debug, it hangs up on an exception. The code is attached. Thanks
Original Attachment has been moved to: mb_6_6_2014.zip
hi, please accept my apology for the time it has taken us to get back to you on this issue.
I've tried your project on my side, it seems works (I did not connect the target MCF51JM128 board to a serial port).
and I did not see the problem hanging up on an exception.
if your problem still remains, then, could you please let me know the steps to reproduce your problem.
it would be better if you could upload an image showing the problem.
