imx6 with jb4.2.2_1.1.0  boot  problem when connected usb touchscreen
Question asked by mrleo on Jun 4, 2014
Latest reply on Mar 9, 2015 by mrleo
Hi all,
If i don't connect usb interface touchscreen(eGTouch),the android4.2.2 system will boot ok in my custom board which based imx6q sabresd board.
But when I connected usb interface touchscreen(eGTouch),boot the android4.2.2 system will all hang the android logo place.
logcat can see some error :
E/BatteryService( 2623): acOnlinePath not found
E/BatteryService( 2623): usbOnlinePath not found
E/BatteryService( 2623): wirelessOnlinePath not found
E/BatteryService( 2623): batteryStatusPath not found
E/BatteryService( 2623): batteryHealthPath not found
E/BatteryService( 2623): batteryPresentPath not found
E/BatteryService( 2623): batteryCapacityPath not found
E/BatteryService( 2623): batteryVoltagePath not found
E/BatteryService( 2623): batteryTemperaturePath not found
E/BatteryService( 2623): batteryTechnologyPath not found
I/sysproc ( 2623): Entered system_init()
I/sysproc ( 2623): ServiceManager: 0x63f9e520
D/SensorService( 2623): nuSensorService starting...
E/Sensors ( 2623): couldn't find 'mma845x' input device
F/libc    ( 2623): *** strlen read overflow detected ***
F/libc    ( 2623): Fatal signal 11 (SIGSEGV) at 0xdeadbaad (code=1), thread 2623 (system_server)
I/DEBUG   ( 2311): *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
I/DEBUG   ( 2311): Build fingerprint: 'Freescale/sabresd_6dq/sabresd_6dq:4.2.2/1.1.0-rc3/eng.leo.20140408.111734:user/dev-keys'
I/DEBUG   ( 2311): Revision: '405522'
I/DEBUG   ( 2311): pid: 2623, tid: 2623, name: system_server  >>> system_server <<<
I/DEBUG   ( 2311): signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr deadbaad
I/DEBUG   ( 2311):     r0 00000027  r1 deadbaad  r2 401a9258  r3 00000000
I/DEBUG   ( 2311):     r4 00000000  r5 beeb428c  r6 4004a64d  r7 40be3008
I/DEBUG   ( 2311):     r8 beeb4315  r9 4004a4da  sl 4004a4e2  fp 00000000
I/DEBUG   ( 2311):     ip 00000000  sp beeb4288  lr 4017c339  pc 401789d2  cpsr 60000030
I/DEBUG   ( 2311):     d0  3f80000044800000  d1  0000000100259398
I/DEBUG   ( 2311):     d2  00000001d5b733de  d3  3f1155e54e7e8408
I/DEBUG   ( 2311):     d4  0000000000000000  d5  3ff0000000000000
I/DEBUG   ( 2311):     d6  002d200000000963  d7  000003333f4ccccd
I/DEBUG   ( 2311):     d8  0000000000000000  d9  0000000000000000
I/DEBUG   ( 2311):     d10 0000000000000000  d11 0000000000000000
I/DEBUG   ( 2311):     d12 0000000000000000  d13 0000000000000000
I/DEBUG   ( 2311):     d14 0000000000000000  d15 0000000000000000
I/DEBUG   ( 2311):     d16 3fe99999a0000000  d17 3fe999999999999a
I/DEBUG   ( 2311):     d18 0000000000000000  d19 0000000000000000
I/DEBUG   ( 2311):     d20 3fc554e7eb0eb47c  d21 3e66376972bea4d0
I/DEBUGhub 2-1:1.0: Cannot enable port 4.  Maybe the USB cable is bad?
   ( 2311):     d22 3f4de16b9c24ahub 2-1:1.0: unable to enumerate USB device on port 4
98f  d23 3fb0f4a31edab38b
I/DEBUG   ( 2311):     d24 3fede16b9c24a98f  d25 3fe55559ee5e69f9
I/DEBUG   ( 2311):     d26 0000000000000000  d27 0000000000000000
I/DEBUG   ( 2311):     d28 0000000000000005  d29 0000000000000000
I/DEBUG   ( 2311):     d30 0000000000000000  d31 0000000000000000
I/DEBUG   ( 2311):     scr 20000090
I/DEBUG   ( 2311):
I/DEBUG   ( 2311): backtrace:
I/DEBUG   ( 2311):     #00  pc 0001a9d2  /system/lib/libc.so
I/DEBUG   ( 2311):     #01  pc 000180ac  /system/lib/libc.so (abort+4)
I/DEBUG   ( 2311):     #02  pc 0002572b  /system/lib/libc.so (__strlen_chk+26)
I/DEBUG   ( 2311):     #03  pc 00002539  /system/lib/hw/sensors.SABRESD.so (SensorBase::sensorBaseGetSysfsPath(char const*)+220)
I/DEBUG   ( 2311):     #04  pc 00002d93  /system/lib/hw/sensors.SABRESD.so (AccelSensor::AccelSensor()+46)
I/DEBUG   ( 2311):     #05  pc 00001bf3  /system/lib/hw/sensors.SABRESD.so (sensors_poll_context_t::sensors_poll_context_t()+14)
I/DEBUG   ( 2311):     #06  pc 00001cef  /system/lib/hw/sensors.SABRESD.so
I/DEBUG   ( 2311):     #07  pc 0000e005  /system/lib/libsensorservice.so (android::SensorDevice::SensorDevice()+148)
I/DEBUG   ( 2311):     #08  pc 0000dd55  /system/lib/libsensorservice.so (android::Singleton<android::SensorDevice>::getInstance()+32)
I/DEBUG   ( 2311):     #09  pc 0000fea3  /system/lib/libsensorservice.so (android::SensorService::onFirstRef()+22)
I/DEBUG   ( 2311):     #10  pc 0000ef2d  /system/lib/libutils.so (android::RefBase::incStrong(void const*) const+38)
I/DEBUG   ( 2311):     #11  pc 00001163  /system/lib/libsystem_server.so
I/DEBUG   ( 2311):     #12  pc 0000127f  /system/lib/libsystem_server.so (system_init+242)
I/DEBUG   ( 2311):     #13  pc 0001e290  /system/lib/libdvm.so (dvmPlatformInvoke+112)
I/DEBUG   ( 2311):     #14  pc 0004d411  /system/lib/libdvm.so (dvmCallJNIMethod(unsigned int const*, JValue*, Method const*, Thread*)+396)
I/DEBUG   ( 2311):     #15  pc 000276a0  /system/lib/libdvm.so
I/DEBUG   ( 2311):     #16  pc 0002b57c  /system/lib/libdvm.so (dvmInterpret(Thread*, Method const*, JValue*)+184)
I/DEBUG   ( 2311):     #17  pc 0005ff07  /system/lib/libdvm.so (dvmInvokeMethod(Object*, Method const*, ArrayObject*, ArrayObject*, ClassObject*, bool)+374)
I/DEBUG   ( 2311):     #18  pc 000677e1  /system/lib/libdvm.so
I/DEBUG   ( 2311):     #19  pc 000276a0  /system/lib/libdvm.so
I/DEBUG   ( 2311):     #20  pc 0002b57c  /system/lib/libdvm.so (dvmInterpret(Thread*, Method const*, JValue*)+184)
I/DEBUG   ( 2311):     #21  pc 0005fc31  /system/lib/libdvm.so (dvmCallMethodV(Thread*, Method const*, Object*, bool, JValue*, std::__va_list)+272)
I/DEBUG   ( 2311):     #22  pc 000499fb  /system/lib/libdvm.so
I/DEBUG   ( 2311):     #23  pc 00046871  /system/lib/libandroid_runtime.so
I/DEBUG   ( 2311):     #24  pc 00047533  /system/lib/libandroid_runtime.so (android::AndroidRuntime::start(char const*, char const*)+390)
I/DEBUG   ( 2311):     #25  pc 00000db7  /system/bin/app_process
I/DEBUG   ( 2311):     #26  pc 0001273f  /system/lib/libc.so (__libc_init+38)
I/DEBUG   ( 2311):     #27  pc 00000ae8  /system/bin/app_process
I/DEBUG   ( 2311):
I/DEBUG   ( 2311): stack:
I/DEBUG   ( 2311):          beeb4248  4017b5f9  /system/lib/libc.so (_cleanup)
I/DEBUG   ( 2311):          beeb424c  00000000
I/DEBUG   ( 2311):          beeb4250  00000001
I/DEBUG   ( 2311):          beeb4254  401a9408
I/DEBUG   ( 2311):          beeb4258  61b4b020
I/DEBUG   ( 2311):          beeb425c  00000480
I/DEBUG   ( 2311):          beeb4260  401a6254  /system/lib/libc.so
I/DEBUG   ( 2311):          beeb4264  401a61b4  /system/lib/libc.so
I/DEBUG   ( 2311):          beeb4268  00000000
I/DEBUG   ( 2311):          beeb426c  4017c339  /system/lib/libc.so (_fwalk+32)
I/DEBUG   ( 2311):          beeb4270  00000001
I/DEBUG   ( 2311):          beeb4274  beeb428c  [stack]
I/DEBUG   ( 2311):          beeb4278  4004a64d  /system/lib/hw/sensors.SABRESD.so
I/DEBUG   ( 2311):          beeb427c  40be3008
I/DEBUG   ( 2311):          beeb4280  df0027ad
I/DEBUG   ( 2311):          beeb4284  00000000
I/DEBUG   ( 2311):     #00  beeb4288  40be3008
I/DEBUG   ( 2311):          beeb428c  fffffbdf
I/DEBUG   ( 2311):          beeb4290  401a9408
I/DEBUG   ( 2311):          beeb4294  00000000
I/DEBUG   ( 2311):          beeb4298  401a9da4
I/DEBUG   ( 2311):          beeb429c  3a2d8b35
I/DEBUG   ( 2311):          beeb42a0  00000020
I/DEBUG   ( 2311):          beeb42a4  00000020
I/DEBUG   ( 2311):          beeb42a8  401a9408
I/DEBUG   ( 2311):          beeb42ac  401760b0  /system/lib/libc.so (__pthread_clone)
I/DEBUG   ( 2311):     #01  beeb42b0  3a2d8b35
I/DEBUG   ( 2311):          beeb42b4  4018372f  /system/lib/libc.so (__strlen_chk+30)
I/DEBUG   ( 2311):     #02  beeb42b8  beeb4304  [stack]
I/DEBUG   ( 2311):          beeb42bc  4004953d  /system/lib/hw/sensors.SABRESD.so (SensorBase::sensorBaseGetSysfsPath(char const*)+224)
I/DEBUG   ( 2311):
I/DEBUG   ( 2311): memory near r2:
I/DEBUG   ( 2311):     401a9238 00000007 00000002 00000000 00000000
I/DEBUG   ( 2311):     401a9248 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     401a9258 00000001 00000000 00000000 00000000
I/DEBUG   ( 2311):     401a9268 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     401a9278 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     401a9288 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     401a9298 00000000 00000000 004e1791 00000000
I/DEBUG   ( 2311):     401a92a8 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     401a92b8 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     401a92c8 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     401a92d8 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     401a92e8 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     401a92f8 00000000 00000000 00000000 00004000
I/DEBUG   ( 2311):     401a9308 00000000 00000000 00000000 00004000
I/DEBUG   ( 2311):     401a9318 00000000 00000000 00000000 00004000
I/DEBUG   ( 2311):     401a9328 00000000 00000000 00000000 00004000
I/DEBUG   ( 2311):
I/DEBUG   ( 2311): memory near r5:
I/DEBUG   ( 2311):     beeb426c 4017c339 00000001 beeb428c 4004a64d
I/DEBUG   ( 2311):     beeb427c 40be3008 df0027ad 00000000 40be3008
I/DEBUG   ( 2311):     beeb428c fffffbdf 401a9408 00000000 401a9da4
I/DEBUG   ( 2311):     beeb429c 3a2d8b35 00000020 00000020 401a9408
I/DEBUG   ( 2311):     beeb42ac 401760b0 3a2d8b35 4018372f beeb4304
I/DEBUG   ( 2311):     beeb42bc 4004953d 79656b2d 5f000073 74726956
I/DEBUG   ( 2311):     beeb42cc 61b49fa0 00000018 401a9228 00000ff0
I/DEBUG   ( 2311):     beeb42dc 00000fd9 00000003 6c614765 49207861
I/DEBUG   ( 2311):     beeb42ec 202e636e 20425355 63756f54 6e6f4368
I/DEBUG   ( 2311):     beeb42fc 6c6f7274 0a72656c 7379732f 616c632f
I/DEBUG   ( 2311):     beeb430c 692f7373 7475706e 706e692f 2f327475
I/DEBUG   ( 2311):     beeb431c 656d616e 00000000 00000001 401a9228
I/DEBUG   ( 2311):     beeb432c 40821c8d 408681b0 00000018 40f778c8
I/DEBUG   ( 2311):     beeb433c 736e6573 0073726f 40f72008 0000001e
I/DEBUG   ( 2311):     beeb434c 0000001e 40f77f18 40f77f18 61f6437c
I/DEBUG   ( 2311):     beeb435c 40f77f18 00000003 61f64010 0000001e
I/DEBUG   ( 2311):
I/DEBUG   ( 2311): memory near r6:
I/DEBUG   ( 2311):     4004a62c 3000726f 2e6f7200 6867696c 6e657374
I/DEBUG   ( 2311):     4004a63c 2e726f73 65726874 6c6f6873 30310064
I/DEBUG   ( 2311):     4004a64c 616d6d00 78353438 6f436500 7361706d
I/DEBUG   ( 2311):     4004a65c 616d0073 31313367 706d0030 3131336c
I/DEBUG   ( 2311):     4004a66c 01000035 0203ea01 6e657302 42726f73
I/DEBUG   ( 2311):     4004a67c 47657361 6f507465 614d6c6c 01000078
I/DEBUG   ( 2311):     4004a68c 05040302 65730706 726f736e 65736142
I/DEBUG   ( 2311):     4004a69c 50746547 4d6c6c6f 00006e69 8101b108
I/DEBUG   ( 2311):     4004a6ac 8400b0b0 00000000 8101b108 8400b0b0
I/DEBUG   ( 2311):     4004a6bc 00000000 8101b292 07afb0b0 00000000
I/DEBUG   ( 2311):     4004a6cc 8101b107 8400b0b0 00000000 8101b295
I/DEBUG   ( 2311):     4004a6dc 07aeb0b0 00000000 00000000 00000000
I/DEBUG   ( 2311):     4004a6ec 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     4004a6fc 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     4004a70c 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     4004a71c 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):
I/DEBUG   ( 2311): memory near r7:
I/DEBUG   ( 2311):     40be2fe8 ffffffff ffffffff ffffffff ffffffff
I/DEBUG   ( 2311):     40be2ff8 ffffffff ffffffff 00000000 0000503b
I/DEBUG   ( 2311):     40be3008 4004bde0 00000000 4004a64d 00000000
I/DEBUG   ( 2311):     40be3018 401a8d94 0000000e 00000000 00000000
I/DEBUG   ( 2311):     40be3028 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     40be3038 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     40be3048 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     40be3058 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     40be3068 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     40be3078 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     40be3088 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     40be3098 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     40be30a8 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     40be30b8 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     40be30c8 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):     40be30d8 00000000 00000000 00000000 00000000
I/DEBUG   ( 2311):
I/DEBUG   ( 2311): memory near r8:
I/DEBUG   ( 2311):     beeb42f4 63756f54 6e6f4368 6c6f7274 0a72656c
I/DEBUG   ( 2311):     beeb4304 7379732f 616c632f 692f7373 7475706e
I/DEBUG   ( 2311):     beeb4314 706e692f 2f327475 656d616e 00000000
I/DEBUG   ( 2311):     beeb4324 00000001 401a9228 40821c8d 408681b0
I/DEBUG   ( 2311):     beeb4334 00000018 40f778c8 736e6573 0073726f
I/DEBUG   ( 2311):     beeb4344 40f72008 0000001e 0000001e 40f77f18
I/DEBUG   ( 2311):     beeb4354 40f77f18 61f6437c 40f77f18 00000003
I/DEBUG   ( 2311):     beeb4364 61f64010 0000001e 40f77f18 00000000
I/DEBUG   ( 2311):     beeb4374 4080ee25 40f77f18 00000000 408681b0
I/DEBUG   ( 2311):     beeb4384 0000001e 40f77f18 407e3ef8 00000003
I/DEBUG   ( 2311):     beeb4394 61f64010 00000018 40cf0950 00000007
I/DEBUG   ( 2311):     beeb43a4 00000001 401a9228 40821c8d 408681b0
I/DEBUG   ( 2311):     beeb43b4 00000018 40f77ef8 407e3ef8 00000000
I/DEBUG   ( 2311):     beeb43c4 61f64010 25b15b5e 63c16c98 40f77ef8
I/DEBUG   ( 2311):     beeb43d4 00000000 00000001 61f64010 408681b0
I/DEBUG   ( 2311):     beeb43e4 40802b37 00000001 25b15b5e 408681b0
I/DEBUG   ( 2311):
I/DEBUG   ( 2311): memory near r9:
I/DEBUG   ( 2311):     4004a4b8 746e756f 0a642520 20732500 0073252c
I/DEBUG   ( 2311):     4004a4c8 7379732f 616c632f 692f7373 7475706e
I/DEBUG   ( 2311):     4004a4d8 6e69002f 00747570 616e002f 7200656d
I/DEBUG   ( 2311):     4004a4e8 25732500 6e650073 656c6261 6c6f7000
I/DEBUG   ( 2311):     4004a4f8 696d006c 616d006e 73250078 74617020
I/DEBUG   ( 2311):     4004a508 73252068 20732500 68746170 20732520
I/DEBUG   ( 2311):     4004a518 6c6f702c 696d206c 6564206e 2079616c
I/DEBUG   ( 2311):     4004a528 25006425 61702073 25206874 702c2073
I/DEBUG   ( 2311):     4004a538 206c6c6f 2078616d 616c6564 64252079
I/DEBUG   ( 2311):     4004a548 65642f00 6e692f76 00747570 6c756f63
I/DEBUG   ( 2311):     4004a558 74276e64 6e696620 25272064 69202773
I/DEBUG   ( 2311):     4004a568 7475706e 76656420 00656369 0078756c
I/DEBUG   ( 2311):     4004a578 62616e55 7420656c 706f206f 25206e65
I/DEBUG   ( 2311):     4004a588 55000a73 6c62616e 6f742065 61657220
I/DEBUG   ( 2311):     4004a598 73252064 6e69000a 746c5f74 78756c5f
I/DEBUG   ( 2311):     4004a5a8 002b7200 6c756f43 74276e64 65706f20
I/DEBUG   ( 2311):
I/DEBUG   ( 2311): memory near sl:
I/DEBUG   ( 2311):     4004a4c0 20732500 0073252c 7379732f 616c632f
I/DEBUG   ( 2311):     4004a4d0 692f7373 7475706e 6e69002f 00747570
I/DEBUG   ( 2311):     4004a4e0 616e002f 7200656d 25732500 6e650073
I/DEBUG   ( 2311):     4004a4f0 656c6261 6c6f7000 696d006c 616d006e
I/DEBUG   ( 2311):     4004a500 73250078 74617020 73252068 20732500
I/DEBUG   ( 2311):     4004a510 68746170 20732520 6c6f702c 696d206c
I/DEBUG   ( 2311):     4004a520 6564206e 2079616c 25006425 61702073
I/DEBUG   ( 2311):     4004a530 25206874 702c2073 206c6c6f 2078616d
I/DEBUG   ( 2311):     4004a540 616c6564 64252079 65642f00 6e692f76
I/DEBUG   ( 2311):     4004a550 00747570 6c756f63 74276e64 6e696620
I/DEBUG   ( 2311):     4004a560 25272064 69202773 7475706e 76656420
I/DEBUG   ( 2311):     4004a570 00656369 0078756c 62616e55 7420656c
I/DEBUG   ( 2311):     4004a580 706f206f 25206e65 55000a73 6c62616e
I/DEBUG   ( 2311):     4004a590 6f742065 61657220 73252064 6e69000a
I/DEBUG   ( 2311):     4004a5a0 746c5f74 78756c5f 002b7200 6c756f43
I/DEBUG   ( 2311):     4004a5b0 74276e64 65706f20 7325206e 6c696620
I/DEBUG   ( 2311):
I/DEBUG   ( 2311): memory near sp:
I/DEBUG   ( 2311):     beeb4268 00000000 4017c339 00000001 beeb428c
I/DEBUG   ( 2311):     beeb4278 4004a64d 40be3008 df0027ad 00000000
I/DEBUG   ( 2311):     beeb4288 40be3008 fffffbdf 401a9408 00000000
I/DEBUG   ( 2311):     beeb4298 401a9da4 3a2d8b35 00000020 00000020
I/DEBUG   ( 2311):     beeb42a8 401a9408 401760b0 3a2d8b35 4018372f
I/DEBUG   ( 2311):     beeb42b8 beeb4304 4004953d 79656b2d 5f000073
I/DEBUG   ( 2311):     beeb42c8 74726956 61b49fa0 00000018 401a9228
I/DEBUG   ( 2311):     beeb42d8 00000ff0 00000fd9 00000003 6c614765
I/DEBUG   ( 2311):     beeb42e8 49207861 202e636e 20425355 63756f54
I/DEBUG   ( 2311):     beeb42f8 6e6f4368 6c6f7274 0a72656c 7379732f
I/DEBUG   ( 2311):     beeb4308 616c632f 692f7373 7475706e 706e692f
I/DEBUG   ( 2311):     beeb4318 2f327475 656d616e 00000000 00000001
I/DEBUG   ( 2311):     beeb4328 401a9228 40821c8d 408681b0 00000018
I/DEBUG   ( 2311):     beeb4338 40f778c8 736e6573 0073726f 40f72008
I/DEBUG   ( 2311):     beeb4348 0000001e 0000001e 40f77f18 40f77f18
I/DEBUG   ( 2311):     beeb4358 61f6437c 40f77f18 00000003 61f64010
I/DEBUG   ( 2311):
I/DEBUG   ( 2311): code around pc:
I/DEBUG   ( 2311):     401789b0 e000b164 6823461c d1fb2b00 68e3e026
I/DEBUG   ( 2311):     401789c0 4a17b123 447a2401 47986014 20274911
I/DEBUG   ( 2311):     401789d0 70082400 ea66f7fc f7fd2106 a902ebd8
I/DEBUG   ( 2311):     401789e0 f04f2006 460a5380 94029304 f7fc9403
I/DEBUG   ( 2311):     401789f0 4629efbe 20024622 efc6f7fc ea52f7fc
I/DEBUG   ( 2311):     40178a00 f7fd2106 2001ebc4 ef72f7fb 2a006962
I/DEBUG   ( 2311):     40178a10 e7d4d1dc deadbaad 0002d5c6 000308aa
I/DEBUG   ( 2311):     40178a20 0003088e 2400b510 aa04b088 46699002
I/DEBUG   ( 2311):     40178a30 94014620 94039400 ef1ef7fc bfb842a0
I/DEBUG   ( 2311):     40178a40 db054620 b1139b07 1c489906 98069006
I/DEBUG   ( 2311):     40178a50 bd10b008 4604b510 e8a6f7fc d10542a0
I/DEBUG   ( 2311):     40178a60 447b4b04 6018681b bd102000 30fff04f
I/DEBUG   ( 2311):     40178a70 bf00bd10 0002d4fa 460db538 481eb928
I/DEBUG   ( 2311):     40178a80 f7fc4478 2800eca4 b9fdd130 2102481b
I/DEBUG   ( 2311):     40178a90 f0014478 2800faae db274604 f7fc4629
I/DEBUG   ( 2311):     40178aa0 2800eb2e 2101db0b f7fc4620 2800eb28
I/DEBUG   ( 2311):
I/DEBUG   ( 2311): code around lr:
I/DEBUG   ( 2311):     4017c318 41f0e92d 4c0b2600 447c4680 68a56824
I/DEBUG   ( 2311):     4017c328 e0076867 300cf9b5 dd022b00 47c04628
I/DEBUG   ( 2311):     4017c338 35544306 d5f53f01 2c006824 4630d1ef
I/DEBUG   ( 2311):     4017c348 81f0e8bd 00029c62 43f0e92d fb01461f
I/DEBUG   ( 2311):     4017c358 f8dff602 b0878058 44f8460c 8000f8d8
I/DEBUG   ( 2311):     4017c368 9001a901 f8d84615 20013000 96059602
I/DEBUG   ( 2311):     4017c378 90049103 4638b113 fa35f7ff a9034638
I/DEBUG   ( 2311):     4017c388 fe9bf7ff 2000f8d8 b1124681 f7ff4638
I/DEBUG   ( 2311):     4017c398 f1b9fa37 d0050f00 46219d05 f01a1b70
I/DEBUG   ( 2311):     4017c3a8 4605ed46 b0074628 83f0e8bd 00029bda
I/DEBUG   ( 2311):     4017c3b8 1e4b6841 2b006043 f000da01 6803bbab
I/DEBUG   ( 2311):     4017c3c8 2b01f813 46106003 00004770 4604b570
I/DEBUG   ( 2311):     4017c3d8 447e4e0d 68336836 f7ffb10b 6861fa04
I/DEBUG   ( 2311):     4017c3e8 60601e48 bfa22800 f8106820 60205b01
I/DEBUG   ( 2311):     4017c3f8 4620da03 fb8ef000 68324605 4620b112
I/DEBUG   ( 2311):     4017c408 f9fef7ff bd704628 00029b62 447b4b07
I/DEBUG   ( 2311):
I/DEBUG   ( 2311): memory map around fault addr deadbaad:
I/DEBUG   ( 2311):     bee95000-beeb6000 [stack]
I/DEBUG   ( 2311):     (no map for address)
I/DEBUG   ( 2311):     ffff0000-ffff1000 [vectors]
D/Zygote  ( 2313): Process 2623 terminated by signal (11)
I/Zygote  ( 2313): Exit zygote because system server (2623) has terminated
I/Netd    ( 2636): Netd 1.0 starting
W/InterfaceController( 2636): Error (Symbol not found: ) while searching for the interface command fini function
I/ServiceManager( 2308): service 'media.audio_flinger' died
I/ServiceManager( 2308): service 'media.player' died
I/ServiceManager( 2308): service 'media.camera' died
And the /system/bin/netd and /system/bin/mediaserver will exited
My custom board does not have mma845x. maybe need disable mma845x? How to solve this issues? Anyone can give me some advices?
Leo
