Im currently using kl15 in my project and unfortunately it doesn't have eeprom. My project require some strings that need to be save in a nonvolatile memory so I can still access it even after a power interruption.
Erich give a good example here "Configuration Data: Using the Internal FLASH instead of an external EEPROM | MCU on Eclipse". The problem I'm encountering right now is saving a string using this code. Can someone give an insights on how to obtain it.
Thank you very much.
Solved! Go to Solution.
Hello Perla,
Thanks for the response.. Its now answered by Erich here..Configuration Data: Using the Internal FLASH instead of an external EEPROM | MCU on Eclipse
Could you please be more specific? share your code? At this moment I was not able to understand what is your exact problem.
Hello Perla,
