I have a customer using MQXLite with Kinetis K20.
They want to use CW10.x libraries that require malloc() functionality.
MQXLite does allow a task(s) to access and use a user heap. I have tested that successfully.
Is there a way to enable a CW10.x library to access and use that user defined heap with MQXLite or is this just a capability of MQXLite? I have not tested this. Guessing that if we know the _malloc() calling in a library we could do a #define something like “#define _malloc _lwmem_alloc to enable the library to use the MQXLite user heap but not certain if a library is expecting to use its own routine or not.
Any help or finger pointing appreciated.
OK…I just got off a phone call with my customer and he believes doing the #define will work for their system and their libraries. I was thinking customer wanted that capability with CW10.x libraries (development tool libraries) and was wrong. Customer wants to use the MQXLite user heap with their own custom libraries.
So now I do not have any question but figured I would share this email thread in case someone else has similar request from customer.
David
David Seymour
