Hi I was trying to follow Kinetis Design Studio Quick Start Guide. No issue with building but while debugging it shows "arm-none-eabi-gdb --version" error. I am very new to this types to eclipse based tools. Please help.
thanks
Abdullah
Solved! Go to Solution.
This is more a question for the Kinetis Design Studio?
Please have a look at the KDS release notes (Kinetis Design Studio V1.0.1 Beta Release Notes, search for "--version"): it looks you have the problem described there.
Erich
Without open another post, where i can find this botton in KDS for reset the micro? i'm using USBDM. Thanks
Unfortunately, there is no such thing (hardware reset) with GDB. And as KDS is using GDB, this does not exist.
What you have is 'reset and restart', but no 'reset only':
Erich
Ok thanks, i hope this will be inserted in the future if possibile. Thanks
Erich
