Can I use the P&E Micro Multilink Universal FX Debug Interface with CodeWarrior 6.3 for HCS08?
I know that P&E Micro Multilink Universal FX is compatible with Code Warrior 10.2 and higher.
In this forum, I found a patch for the CodeWarrior 5.1 for HCS12(X) in order to use this tool.
Is there something equivalent also for the CodeWarrior 6.3 for HCS08?
Thanks a lot,
Nicola
hi Nicola,
No. P&E Micro Multilink Universal FX can only support CW10.2 and higher version.
see its support list here:
http://www.pemicro.com/products/fx_software.cfm
this answer is for you. if it answers, please click on "correct answer" button. thanks!
ZhangJun
