Is there any documentation on the shape of the waveform onn the BDM line when a MC9S08DV16 is programmed correctly?
nataliemcwillia
I am working on debugging a fixture, failure analysis on a board and trying to eliminate a noise issue on the line.  It would be beneficial to see what the BDM waveform should look like because my programmer keeps getting an error that it isn't programming and I know that I have power and ground and the programming wire hooked up correctly.  I am using the P&E Multilink to program so just wondering if anyone has any info on this.
Thanks!
nataliemcwillia
Oops, meant to say BKGD not BDM
