About video_full_range_flag of H.264 decoder in i.MX6DL.
Question asked by Keita Nagashima on May 27, 2014
Latest reply on Oct 19, 2017 by xie zhiyong
Dear Sir or Madam,
Hello.
BSP : Android (jb4.2.2_1.1.0)
There is a header information [SPS(Sequence Parameter Set)] in the H.264 data.
And there is vui_parameters in SPS(Sequence Parameter Set).
Then, there is video_full_range_flag of the element of vui_parameters.
The intended function of "video_full_range_flag" is to tell the decoder that the content is using the full video range (Computer RGB) and the decoder should not expand the range otherwise clipping will occur.
[Q1]
Is the FSL's H.264 decoder changing RGB<->YUV processing by the value of this flag?
[Q2]
If Q1's answer is No, is it possible to process in the YUV change by the value of the flag?
Keita
