MQX 4.1 Host CDC class driver on K70
arunadas
I need technical inputs w.r.t. MQX CDC class host driver on K70 board.
  1. We are using a USB-cdc Device with K70 board.
  2. On K70, the device is enumerated but the CDC demo always returns failure at the point indicated in the below snapshot.
  3. The implementation in the attached snapshot is from “cdc_serial.c” demo made available by Freescale
  4. Specificaly the attached snapshot is from "data-event" callback registered by the application.
  5. Since the BOUND_CONTROL_INTERFACE is always NULL, “_lwevent_set” never occurs.
Please provide me pointers to debug and fix this issue.
Kan_Li
Hi Aruna das,
I have taken your SR for this topic, so I will answer thru CRM, thanks for your patience and understanding:smileyhappy:
Have a great day!
B.R
Kan
