K60n512 wifi with Gain Span (GS1500M)
Question asked by Tucker Downs on May 22, 2014
Latest reply on Jun 3, 2014 by Perla Andrea Moncada Fajardo
I am trying to use the TWR-WIFI-GS1500M board with the TWR-K60n512 board and can not find a single working example or patch for MQX 3.7 or MQX 4.1.
Initially I was having problems with MQX 4.1 and when I read that a patched version of 3.7 worked great for this configuration I went ahead and downloaded it but have yet to make it work.
With just the TWR SER board in use I can make the web server example run but with the TWR-WIFI board enabled in soft ware the example fails.
I believe that with the wifi enabled I should be able to connect to a network created by the free scale tower (although my end goal is to make the tower connect to another network present) and see the web page served up by the example.
If anyone has made this module work with the k60 board (or any other boards) I would love to know what you did.
Does anyone have any ideas about how this works?
