Processor expert and PWM in Complimentary mode
Question asked by Tsvetan Mudrov on May 19, 2014
Latest reply on May 28, 2014 by Ankur Kala
Hello. I'm using CW.10.6 with PE on K20 device. I'm trying to set a 2 channel PWM in Complimentary mode. As I understand, the right component in PE should be Init_FTM. But it doesn't have any user interface, except initialization function of the module. As minimum, I need enable and disable functions, to start and stop the outputs generation.
The other option is to use two PWM components, but I don't see a easy way to command them in synchronous way (start/stop the outputs).
Did I miss something in PE?
