GDI:   Breakpoints not available in the GDI DLL
mithunbharadwaj
GDI: Reading From Memory Address: 0x030, count: 1
GDI: DiMemoryRead()==> DI_OK
GDI: 00
GDI: Writing To Memory Address: 0x028, count: 2
GDI: 00 00
GDI: DiMemoryWrite()==> DI_OK
GDI: Reading From Memory Address: 0x028, count: 2
GDI: 00 00
GDI: DiExecSingleStep(1)==> DI_OK
GDI: Reading From Memory Address: 0x0FC70, count: 1
GDI: 06
GDI: Writing To Memory Address: 0x0FC70, count: 1
GDI: 00
GDI: 06
GDI: Breakpoints not available in the GDI DLL.
GDI: Writing To Memory Address: 0x02A, count: 1
This is part of the command window output.
I am trying to debug on the target. Even if i set a breakpoint It is not encountered.
The breakpoints is set at address 0x0FC70, The flow of PC does not stop after encountering breakpoint.
I am using codewarrior IDE version 5.9.0 build 5294
How to enable breakpoints??
Rick_Li
Please let me know your target MCU's partnumber.
and please also let me know steps on reproducing this problem.
mithunbharadwaj
The target is S12G48
When i give debug in the codewarrior, the True-time simulator and real time debugger window opens.
Here go to source window and set a break point.
Then reset the target.
Now give start/ continue.
At this stage, In the command window the breakpoint if created and encountered, will be displayed.
In my case break point is not encountered and i get the message given below.
Rick_Li
it seems the problem is caused by some problem of your own code.
I can't reproduce the problem with your steps.
please upload your application here for my further investigating.
mithunbharadwaj
I think i have found the problem source.
The derivative ID is 0x1C5,
But it is shown as (Unknown) 0x1C5 in the Real-time Debugger window.
This is preventing the breakpoints from being set.
I need updated configuration file for selecting the MC9S12G48 MCU.
