Do you have experience with the MC33816 Assembler?
hwahnrodriguez
I'm working with KITMC33816AEEVM.  I download the files necessary to run the demo and is running fine.  I can modify the source code and assemble with the MC338616 Assembler.  I have the assembled and configuration files but the Data  RAM files come out with all zero's.  Any idea what the problem may be?  Thanks.
Sauda
Hi Juan,
I have also working on the same module and facing the same problem.
What shall I need to do to solve this problem?
Sateesh
hwahnrodriguez
Hi Sateesh,
I did get it working.
You need to enter the values into the Data RAM manually and save them. The address of each data is directly tied to the #define declarations in the Code RAM.
Juan
Sauda
Hi Juan,
Thank you for the reply.
Its working.
Have a nice day.
Sateesh
On Tue, Jul 1, 2014 at 7:32 PM, Juan Rodriguez <
hwahnrodriguez
:O)
TomasVaverka
Hi Juan,
I believe that Pierre has already contacted you directly and clarified your questions regarding the KITMC33816AEEVM.
If there are still any other questions, please let us know.
Tomas
hwahnrodriguez
Hi Tomas,
That's correct. I've been in contact with Pierre. No questions at this point. We are going forward with this device, so there may be more questions later.
Juan
