i.MX6DQ Android Beam animation issue.
satoshishimoda
Senior Contributor I
Hi community,
I have a question about i.MX6DQ Android BSP.
When use Android Beam with jb4.2.2_1.0.0, a animation works on the background.
If repeat this animation, android will freeze and reboot without any log.
And if disable watchdog, the issue will be only freeze and reboot is not occurred.
On the other hand, this issue is resolved by jb4.2.2_1.1.0.
So we think some patch resolves this issue, and we want to know what patch do it.
Could you let me know what patch file resolves it?
Satoshi Shimoda
Labels (3)
SergioSolis
It appears to be an issue with the GPU driver.  Is there a reason for not moving to 4.2.2.1.1 ?
You can try the GPU driver from 4.2.2.1.1 in 4.2.2.1.0 (attached).
You can find jb4.2.2_1.1.0 GPU user space binaries in attach, please apply them on your board.
There are five GPU patches in kernel, you can find them in attach, please apply them to jb4.2.2_1.0.0 kernel and re-build the boot.img.
SergioSolis
jamesbone
SergioSolis, can you please comment?
YixingKong
Senior Contributor IV
SergioSolis, could you help in following the request, or do you need help from others?
Yixing
YixingKong
Yixing
satoshishimoda
Could you let me know your status?
I would appreciate if you send me a reply as soon as possible.
Satoshi Shimoda
