Setting the Default Variable Format
Question asked by Dave Wills on May 14, 2014
Latest reply on May 17, 2014 by Dave Wills
CodeWarrior 10.6
I'm looking at variables (local only?) and expressions (variables added to the watch window?) while debugging.  I'd like to change the format to something other than ASCII and have it stick.  I don't see a way to do this.
There are a couple of different problems.  If the variable is an array and I want to view in hex, is there a way to change the format for the entire array?
Is there a way to set the default format to something other than ASCII?
When the format is manually changed, why does CodeWarrior set it back to the default ASCII as  you step in and out of functions?  That makes it extremely difficult to debug anything unless you're used to working in ASCII.
Thanks!
d.
