Flexbus read and write issue in MQX
Question asked by Dawei You Employee on May 14, 2014
Latest reply on May 22, 2014 by Daniel Chen
Hi:
I follow Flexbus demo case in MQX to write CAN application,
compared with original demo, I use mulitple mailbox for read/write.
But this application only can TX or RX, for example: one node run TX task, another run RX task, which is OK.
But the node run RX and TX togrther, which couldn't run well, it couldn't receive corrent data from another node, even can't enter into ISR.
the code run two nodes is same, only node ID is different.
So please help check attached file, thx!
Original Attachment has been moved to: test.h.zip
Original Attachment has been moved to: fc.c.zip
