Fangnan Wu
does PC8013-61540-120443 cpu have problems for the demoboard of 56F8013
Discussion created by Fangnan Wu on Aug 27, 2007
Latest reply on Aug 27, 2007 by Pascal Irrle
Hi:
I used CW7.3 and now CW8.0(special edition), use beans to setup ADC interrupt,PWM, and TMR. the problem that I am having right now is no matter how i setup beans, it just does not go into adc or pwm interrupts. however if i write code without PE beans (which is combination of c and assemble), it actually can go into pwm interrupt. so I want to know that if this PC8013 has some problem on PE initialization? otherwise I do not know why it can not go into adc interrupt.
Thanks!!
