the problem has solved,we must modify the file asic.c in kernel
I'm also try to get cs4344 chip working om my imx6DL with kernel 3.10.53
What do you change on the kernel to get this working.
I already added sound/soc/codecs/cs4344.c and also sound/soc/fsl/imx-cs4344.c
It is registered in my kernel, but i don,t get audio out of it.
Same issue, try to use CS4344 under Android 4.4.3, but not success.
Any comments?
Hi Jony,
for hardware connections one can use as example WM8962
included in SPF-27392 rev.C3.pdf of Sabre SDB schematic.
As for software please look at i.MX_6Dual6Quad_BSP_Porting_Guide.pdf
Chapter 8 Porting Audio Codecs to a Custom Board.
It is included in Linux Doc bundle below
Also check cs42888.c in SDK:
"MX6_PLATFORM_SDK "
chip
