Hello
Hard to figure out what is going on without more information.
Some points you may want to check:
- Is the Watchdog (COP) enabled? Can you try to disable it or clear it some place.
- Are you able to step through the code or is the application really staying frozen in the
EntryPoint function?
- What is displayed in the Assembly component? Is that valid code?
- Which version of CodeWarrior are you using?
To retrieve that info:
- Start CodeWarrior
- Select Help -> About Freescale CodeWarrior
- Click on "Install Products"
- CodeWarrior version used is displayed on top in the Installed Products dialog.¨
CrasyCat
