Using Ltib images in IMX28
ganeshh
I successfully compiled Ltib and created images in ltib/rootfs/boot/
What are the next steps to boot this image from memory card? Which all files must be copied to memorycard? In one document it says mk_mx28_sd script but BSP doesnt have that script.
Labels (3)
Yuri
Please use the Linux scripts below.
https://www.freescale.com/webapp/Download?colCode=IMX28_LINUX_SCRIPTS&location=null&fasp=1&WT_TYPE=U...
Summary Page :
i.MX280: i.MX280 Multimedia Applications Processor
Note, the scripts may depend on Linux host release, therefore please check them carefully
regarding Your Linux.
Yuri
ganeshh
Thank you i will download the script. But how to configure the sd card does it need partitions which files must be copied to the memorycard
Yuri
"mk_mx28_sd" script burns the kernel, it finds in imx28_ivt_linux.sb
file located in your {ltib}/rootfs/boot/ director,y and the root filesystem
(whole {ltib}/rootfs directory) to SD card.
  To be more exact first it creates 3 partitions on the card:
FAT partition for user data, kernel partition and ext2 one for root filesystem.
Then it burns the kernel on raw /dev/sdb2 and copies {ltib}/rootfs to fresh
/dev/sdb3 partition.
Yuri
gonfer
Contributor V
It should be in your Ltib installation directory.
If it's not there, you can download it from i.MX280: i.MX280 Multimedia Applications Processor, under Updates and patches.
Gonzalo.
