Hi communty
Do you have a data about "input" load capacitance of i.MX6DQ CSI0_DAT pins?
Especially, we want to know about CSI0_DAT4, CSI0_DAT5, and CSI0_DAT7 pins.
Satoshi Shimoda
Solved! Go to Solution.
To know capacity values of i.MX6 signals - please use corresponding IBIS model.
(assuming standard input model scheme, specified in IBIS )
Also let me remind, if R_pin, L_pin, and C_pin parameters (FOR THAT PIN ONLY !)
are not declared, this means the default package values (R_pkg, L_pkg, C_pkg,
specified under [Package]) should be used.
Yuri
Yuri
