Hello Friends,
I am using kernel 3.10.32 on imx28evk board. Please find the attached config file with the post. Even I have selected CONFIG_SUSPEND is selected, there is no standby option under /sys/power/state.
Command:
root@imx28evk:~# cat /sys/power/state
freeze mem
Snipp of config file:
CONFIG_SUSPEND=y
CONFIG_SUSPEND_FREEZER=y
CONFIG_PM_SLEEP=y
# CONFIG_PM_AUTOSLEEP is not set
CONFIG_PM_WAKELOCKS=y
CONFIG_PM_WAKELOCKS_LIMIT=100
CONFIG_PM_WAKELOCKS_GC=y
CONFIG_PM_RUNTIME=y
CONFIG_PM=y
CONFIG_PM_DEBUG=y
CONFIG_PM_ADVANCED_DEBUG=y
# CONFIG_PM_TEST_SUSPEND is not set
CONFIG_PM_SLEEP_DEBUG=y
# CONFIG_APM_EMULATION is not set
CONFIG_PM_CLK=y
CONFIG_CPU_PM=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_ARM_CPU_SUSPEND=y
CONFIG_NET=y
Can anyone please give me some hint or clue what I am missing in the config file to enable the standby mode?
Ankur
Original Attachment has been moved to: config.zip
Solved! Go to Solution.
Thank you all..
Atlast, I got success and ported the standby support from 2.6.35 to 3.10.29 kernel..huh !!
Ankur
This is the only option currently supported.
Thank you all..
Ankur
Hello Ankur,
Would you share your success if do you still have it? I really need this..
Portakal
Hello Ankur,
it's been a while, but do you want to share your success? Would be greet!
Jörg Krause
Thank you Fabio,
Could you please share your thoughts:
1) What to do to enable the support (where I can start) for Standby for Kernel version 3.10.32?
2) Which latest kernel supports Standby Mode for imx28?
Ankur
