License CW 10.6
License CW 10.6
Microfelix
hello
2 questions:
1) In order to activate the license cw 10.6 What should I do? Under my license in freescale there is no version CW10.6
2) In order to compile MQX 4.1 - FFS may be fine or license STANDARD need the license PRO.
Maurizio
trytohelp
Hi Maurizio,
The MCU V10.6 is not required a new license file.
The MCU V10.6 can be used with MCU V10.5 license file.
What is the problem with MQX V4.1 ?
Attached you will find Release_Notes.pdf manual.
Please have a look to :
      Appendix B: Freescale MQX™ RTOS Integration
Pascal
