CODE WARRIOR IDE SOFTWARE.
jatinmehta
I am using the above mentioned software. This software is not reading header files like  #include "SD.h" , #include "FAT.h" .
Also i am using uC MPC5606B ,and when i include the header file #inlcude "MPC5606B.h",it doesnot identify ADC.
Can someone suggest some tips.
Thanks in advance.
TICS_Fiona
Could you please check the compiler settings for head file search path?
If this does not help, could you please attach a simple project to help us reproduce the error? Thanks!
jatinmehta
hi,TICS_Fiona
I have attached the project do see and any suggestions are welcome.
thanks.
trytohelp
Hi Jatin,
Unfortunately nothing was attached to your post.
Can you check it again ?
If you've problem you can post your problem to the Customer Service Request process.
  - Go to following URL: http://www.freescale.com/TechSupport
  - Click on Submit a Service Request. You will come to a login page.
  - If you are already registered with Freescale (using the Forum, subscribed to newsletter, ...) use your Freescale login and password. Otherwise, Click on "Register Now" to get registered.
  - You can submit your request through the web from there.
Pascal
