DEar CW,
Declaring variables inside the for loop statement:
for(uint8_t Chr = 0; Chr < ITEM_TEXT_LENGTH; Chr++)
Versus not:
uint8_t Chr;
for(Chr = 0; Chr < ITEM_TEXT_LENGTH; Chr++)
Declaring variables inside the for loop statement throws this error:
‘for’ loop initial declarations are only allowed in C99 mode
It certainly isn’t a problem to move the declarations outside of the for loop, but I’d like to have the option of using C99 or know where it is. Do you know if there is a checkbox or command line switch for GCC somewhere?
hy
Right-click on project | Properties | C/C++ Build | Settings | Tool Settings tab | ARM Ltd Windows GCC Compiler | Miscellaneous | Language Standard.
