Both my PC and the Cyclone Max are on the 192.168 side of a router. It works for debugging so I think I have the Gateway, Subnet, and IP setup correctly. And some times it connects Immediately, compiles, and starts the download to the target,,, But more often than not it can takes over 60 seconds to connect before it starts the download. Is there a "trick" to get it to connect Immediately all the time??? This minute to connect adds up fast with many change a line and test cycles. Not to mention how annoying it is. Especially since the compile time is trivial,,, the hold up looks to me like it is the connection. Any one else have this problem,,, anyone know of a fix.
Windows7 64 bit
Router D-Link DIR-651
Setup "looks" like this
{Corporate intranet}
[Router]
[PC] [Cyclone Max]=[Target]
Solved! Go to Solution.
PE Micro Support was very Helpfull
Hi James,
Please go to project settings -> Debugger -> Remote Debugging -> Pemicro_TCPIP
connection -> Edit Connection.
In attached window, please make sure that Speed variable is set to 0 (lowest
possible value). The higher this value, the bigger is the prescaler and the
slower your target communication rate will be.
Please let me know if it speeds up the Cyclone MAX performance you are
observing.
Zahar
P&E
Hi James,
observing.
Zahar
P&E
Hello James,
to investigate the problem we need to know exactly the tool version you're using.
To do that you must:
Under CodeWarrior IDE (classic)
Start the IDE and click on Help | About Freescale CodeWarrior.
Click on Installed Products
Provide us all info displayed.
Or you can save them in a txt file.
The Cyclone interface is manufactured by P&E.
What is the revision of this interface ?
We could contact P&E to have their feedback too.
Pascal
Thanks for the Reply Pascal,
This is the contents of my Installed Plugins
Installed Products:
CodeWarrior Development Studio for ColdFire Architectures Version 7.1, Build 14
CodeWarrior Development Studio for ColdFire Architectures Version 7.1.2 Patch, Build 11
IDE Version: 5.9.0 Build 3024
Plugins: 107
ASINTPPC.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:47 AM 628K
CmdIDE.exe 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:16 AM 41K
IDE.exe 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:09 AM 10.22M
IDENewDialog.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:47 AM 201K
IDE_MFC60cw.dll 6.00.8665.0 6.0.8665.0 6.0.4.0 7/9/2008, 5:38 AM 1.59M
IDE_MSL_DLL90_x86.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:32 AM 296K
InstallHelperKeys.exe No Version Info 0.0.0.0 0.0.0.0 3/22/2005, 11:01 AM 76K
lmgr8c.dll No Version Info 0.0.0.0 0.0.0.0 5/2/2005, 11:09 AM 832K
MWCore5_0.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:39 AM 236K
MWRADUtils.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:47 AM 260K
Mwregsvr.exe 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:52 AM 36K
MWRegSvrWinApp.exe 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:52 AM 36K
PluginLib.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:33 AM 120K
PluginLib2.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:33 AM 120K
PluginLib3.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:33 AM 120K
PluginLib4.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:34 AM 84K
PluginLib5.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:34 AM 84K
PluginLib6.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:35 AM 84K
SHW32.DLL 4.0.1.0 4.0.1.0 2/10/2000, 5:15 PM 110K
tcl84t.dll 8.4.12 8.4.2.12 8.4.2.12 9/25/2006, 2:22 PM 576K
utf8conversion.dll No Version Info 0.0.0.0 0.0.0.0 2/15/2008, 12:47 PM 524K
xerces-2_2_0.dll 2, 2, 0 2.2.0.0 2.2.0.0 7/9/2008, 5:51 AM 2.14M
Bin\Plugins\COM
DebugRegisterMgr.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:29 AM 116K
LogPoint.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:22 AM 56K
FlashProgrammer.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:26 AM 5.60M
HardwareDiagnostics.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:27 AM 2.09M
LoadSaveFill_CF.dll 5.8.0.0 5.8.0.0 5.8.0.0 7/11/2008, 5:35 AM 174K
MakefileExporter.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:14 AM 256K
MWActivate.dll 5.9.0.3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:17 AM 600K
ObjectInspector.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:13 AM 332K
PackAndGo.dll 1,0,0,0110 1.0.0.72 1.0.0.72 7/11/2008, 5:39 AM 344K
PausePoint.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:22 AM 100K
pe_init.exe No Version Info 0.0.0.0 0.0.0.0 5/5/2009, 12:13 PM 92K
PE_Plugin.dll 4.27.0.5077 4.27.0.5077 4.27.0.5077 5/5/2009, 9:03 AM 7.42M
SaveRestoreRegisters.dll 5.7.0.0 5.7.0.0 5.7.0.0 7/11/2008, 5:36 AM 180K
ScriptPoint.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:23 AM 124K
SkipPoint.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:23 AM 52K
SoundPoint.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:23 AM 56K
TipOfTheDay.dll 1,0,0,0110 1.0.0.72 1.0.0.72 7/11/2008, 5:39 AM 64K
DebugDatabase.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:29 AM 296K
VariableFormatter.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:24 AM 52K
CPPCodeCompletion.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:16 AM 808K
CommandWindow.dll 5.9.0.3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:21 AM 1.01M
ColdFireWizard.dll 5.2.0110 5.2.0.72 5.2.0.72 7/11/2008, 5:39 AM 928K
Bin\Plugins
Bin\Plugins\Compiler
MCFCCompiler.dll 7.0 build 37 5.3.0.37 5.3.0.37 11/20/2008, 12:47 AM 2.57M
PCLintCompiler.dll 1.5 1.5.0.5 1.5.0.5 9/4/2003, 4:58 PM 80K
asm_mcf_elf.dll 7.0 build 37 5.0.0.37 5.0.0.37 11/20/2008, 12:50 AM 290K
ELFImporter.dll 1.0 Build 0005 1.0.0.5 1.0.0.5 11/20/2008, 12:50 AM 39K
Bin\Plugins\Debugger
CFDebugger.DLL 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:34 AM 786K
DisassemblerCF.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:32 AM 84K
Dwarf2Symbolics_2_5.DLL 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:19 AM 280K
DwarfSymbolics.DLL 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:18 AM 240K
StabSymbolics.DLL 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:18 AM 156K
Bin\Plugins\Debugger\protocols
CFAbatronProtocol.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:34 AM 199K
CFCCSProtocol.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:35 AM 297K
CFGDIProtocol.dll 7.0.0.111 7.0.0.111 7.0.0.111 4/29/2009, 11:17 AM 135K
PEMicroProtocol.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:34 AM 148K
Bin\Plugins\Linker
BatchRunnerPostLinker.dll 2.0.0 Build 8 2.0.0.8 2.0.0.8 7/11/2008, 8:44 AM 44K
BatchRunnerPreLinker.DLL 1.0.0 Build 6 1.0.0.6 1.0.0.6 7/11/2008, 8:44 AM 45K
ExternalBuildLinker.dll 5.9.0.3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:41 AM 80K
MCFLinker.dll 7.0 build 37 5.1.0.37 5.1.0.37 11/20/2008, 12:47 AM 348K
PCLintLinker.dll 1.5 1.5.0.5 1.5.0.5 9/4/2003, 4:58 PM 84K
Bin\Plugins\Preference_Panel
GDIRconn.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:36 AM 54K
PAssemblerCF.dll 5, 0, 0, 1 5.0.0.1 5.0.0.1 11/20/2008, 12:50 AM 198K
PBackEndCF.dll 7.0 build 37 5.3.0.37 5.3.0.37 11/20/2008, 12:50 AM 77K
PBatchRunnerPostLinker.dll 2.0.0 Build 6 2.0.0.6 2.0.0.6 7/11/2008, 8:44 AM 45K
PBatchRunnerPreLinker.dll 1.0.0 Build 5 1.0.0.5 1.0.0.5 7/11/2008, 8:44 AM 30K
PCFGlobalOptimizer.dll 5.3.0.37 3.0.3.37 3.0.3.37 11/20/2008, 12:50 AM 33K
PCFTarget.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:37 AM 84K
PCLintOptions.dll 1.5 1.5.0.5 1.5.0.5 9/4/2003, 4:58 PM 41K
PCLintSettings.dll 1.5 1.5.0.5 1.5.0.5 9/4/2003, 4:58 PM 82K
PDebugCFExcept.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:37 AM 33K
PDebugCFInterrupt.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:37 AM 9K
PDebugCFReset.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:37 AM 52K
PDebuggerPICSettings.dll 1.2.3.777 1.2.3.777 1.2.3.777 7/11/2008, 5:37 AM 50K
PDebugx86Except.dll 5.9 Build 3024 5.8.0.0 5.8.0.0 7/9/2008, 6:43 AM 64K
PDisassemblerELF.dll 1.2.0 Build 3 1.2.0.3 1.2.0.3 11/20/2008, 12:50 AM 45K
PExternalBuild.dll 1.0.1.0 1.0.1.0 1.0.1.0 7/9/2008, 6:41 AM 64K
PFrontEndC.dll 5.3 37 5.3.0.37 5.3.0.37 11/20/2008, 12:51 AM 68K
PLinkerCF.dll 7.0 build 37 5.1.0.37 5.1.0.37 11/20/2008, 12:50 AM 49K
pMWCVS.dll No Version Info 0.0.0.0 0.0.0.0 10/30/2003, 10:08 AM 64K
pmwSourceSafe.dll 5.5.1.40704 5.5.1.40704 5.5.1.40704 4/8/2004, 1:37 PM 29K
PnESerialCycMaxRconn.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:36 AM 50K
PnETCPIPCycMaxRconn.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:36 AM 49K
PnEUSBCycMaxRconn.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:36 AM 27K
PnEUSBRconn.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:36 AM 27K
PPreprocessorC.dll 5.3 37 5.3.0.37 5.3.0.37 11/20/2008, 12:51 AM 72K
PProjectCF.dll 7.0 build 37 5.1.0.37 5.1.0.37 11/20/2008, 12:50 AM 30K
PRConnCCS.dll 1.0.0.2 b002 1.0.0.2 1.0.0.2 7/11/2008, 5:37 AM 84K
PRConnEthernetTapBDM.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:37 AM 53K
PRConnPELightning.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:36 AM 27K
PRConnPnE.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:36 AM 27K
PRConnTCP.dll 5.9 Build 3024 5.8.0.0 5.8.0.0 7/9/2008, 6:28 AM 36K
PRConnUSBTapBDM.dll 7.0.0.110 7.0.0.110 7.0.0.110 7/11/2008, 5:36 AM 54K
PSerialComm.dll 5.9 Engineering Build 5.8.0.0 5.8.0.0 7/11/2008, 5:36 AM 29K
PSourceFolderMapping.dll 5.9 Engineering Build 5.8.0.0 5.8.0.0 7/11/2008, 5:37 AM 52K
PTcpIpComm.dll 5.9 Engineering Build 5.8.0.0 5.8.0.0 7/11/2008, 5:36 AM 22K
PWarningC.dll 5.3 37 5.3.0.37 5.3.0.37 11/20/2008, 12:51 AM 68K
Bin\Plugins\Support\ColdFire\Abatron
bdiifc32.dll V1.44 1.0.4.4 1.0.4.4 8/16/2007, 7:47 AM 116K
Bin\Plugins\Support
CPlusSourceGen.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:12 AM 272K
MWComBase.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:44 AM 64K
MWComHelpers.DLL 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:40 AM 460K
MWRadModel.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:47 AM 572K
ObjectWireWizard.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:37 AM 136K
Bin\Plugins\Support\ColdFire\OSBDM
osbdm-jm60_gdi_cfv234.dll 1, 0, 12, 1 1.0.12.1 1.0.12.1 7/6/2009, 4:05 PM 51K
Bin\Plugins\Support\ColdFire\pemicro
unit_cfz.dll 3.25.0.0 3.25.0.0 3.25.0.0 7/23/2007, 6:23 PM 1.55M
Bin\Plugins\Support\Common\Comm_IO
PP_TargetAccess.dll 5.8.0.3024 5.8.0.3024 5.8.0.3024 7/9/2008, 6:25 AM 60K
Bin\Plugins\Support\Flash_Programmer\File_IO
BIN_File_IOEngine.dll 5.8.0.3024 5.8.0.3024 5.8.0.3024 7/9/2008, 6:25 AM 26K
ELF_File_IOEngine.dll 5.8.0.3024 5.8.0.3024 5.8.0.3024 7/9/2008, 6:25 AM 21K
SREC_File_IOEngine.dll 5.8.0.3024 5.8.0.3024 5.8.0.3024 7/9/2008, 6:25 AM 35K
Bin\Plugins\Support\Sim\ccssim2\bin
ccssim.dll No Version Info 0.0.0.0 0.0.0.0 12/1/2005, 11:11 PM 815K
ccssim2.exe No Version Info 0.0.1.1 0.0.1.1 10/20/2004, 4:24 AM 153K
elfioloader.dll No Version Info 0.0.0.0 0.0.0.0 10/20/2004, 4:24 AM 227K
libcf2e.dll No Version Info 0.0.0.0 0.0.0.0 10/20/2004, 4:24 AM 228K
libcf2iss.dll No Version Info 0.0.0.0 0.0.0.0 3/22/2006, 3:41 PM 184K
libcf4e.dll No Version Info 0.0.0.0 0.0.0.0 10/20/2004, 4:24 AM 232K
libcf4iss.dll No Version Info 0.0.0.0 0.0.0.0 10/6/2005, 6:07 PM 488K
lmgr8c.dll No Version Info 0.0.0.0 0.0.0.0 11/17/2004, 5:45 PM 832K
tcl82.dll 8.2.3 8.2.2.3 8.2.2.3 10/20/2004, 4:24 AM 456K
tk82.dll 8.2.3 8.2.2.3 8.2.2.3 10/20/2004, 4:24 AM 817K
winico03.dll No Version Info 0.0.0.0 0.0.0.0 10/20/2004, 4:24 AM 77K
Bin\Plugins\version_control
mwcvs.dll No Version Info 0.0.0.0 0.0.0.0 10/30/2003, 10:08 AM 232K
mwSourceSafe.dll 1.0.3.716 1.0.3.716 1.0.3.716 4/8/2004, 1:37 PM 137K
VCSClearCase.dll 1.1.2.1999 1.1.2.1999 1.1.2.1999 8/16/2004, 1:18 PM 76K
Bin\resource
CPlusResources.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:10 AM 24K
ExternalBuildResources.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:41 AM 6K
IDEAuxiliaryResources.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:40 AM 44K
IDEResources.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 5:40 AM 52K
MakefileResources.dll 5.9.0 Build 3024 5.9.0.3024 5.9.0.3024 7/9/2008, 6:10 AM 12K
