It might be too trivial, but could someone help with a formula to calculate the time elapsed from the time base registers on PowerQUICC?
Thanks.
Solved! Go to Solution.
There is an example in BOOK_EUM.pdf, inculding compute code sequence, see Section 8.4.4 Computing Time of Day from the Time Base. The doc could be download from www.freescale.com
Thanks!
