I start the manufacturing tool and try to download an existing imgae. The tool finds our iMX6Q, checks the image and just before stating "Loading u-boot..." I get a message: No device connected". What does that message really mean? Cannot find the memory or the CPU? Interesting also is, the tool does not give an error - though it seem to hang. Any ideas?
Solved! Go to Solution.
Sorry for my late reply.
The problem was related to the invalid Image I tied to load. Drivers and configuration was correct.
Usually MFGTool creates a Log in the same directory where the .exe is, can you please verify if there is one?.
Are all the necessary drivers installed?
