hi,
when i am debugging my usb code using PEDBM and it is stop in _asm(nop) at this address program counter does not goes to next address. When i press pause the running code i get a error code that .....invalid preference was pass to the GDI protocol....plz tell me any solution on that and cause of the error.
Panks
Please check the below threads and let me know if this helps,
CW ColdFire 7.2. Eval "ColdFire gdi Protocol Adapter: can't connect"
https://community.freescale.com/thread/55043
a newby's connection problems with OSBDM
Sol
