boot error on Ubuntu oneiric
wenjingyang
When I boot i.mx6 from SD card with Ubuntu oneiric, I got some errors. I have no idea of what it is.
modem-manager[4115]: <info>  ModemManager (version 0.5) starting...
modem-manager[4115]: Could not get the system bus. Make sure the message bus daemon is running! Message: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
wenjingyang
Dan
      I found finally that I misunderstood the steps to burn the ubuntu image. I shouldn't non-GUI cover rootfs by ubuntu demo rootfs. I should unzip the ubuntu demo rootfs just after SD format.
wenjingyang
Dan
Rita_Wang
Hi wenjing,
I am so glad to hear that you have solved this problem. If any questions, create new threads in this community.
Best Regards
Dan
Rita_Wang
Hi wenjing,
You met "Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory". This is caused by missing package dbus. You can install it when your ubuntu is running .
Hope this can help you~~
Have a great day
Best Regards
Dan
wenjingyang
Hi, Dan
     Thanks for your replay.
     During I unzip oneiric.gz, I met several error: "tar: var/run: Cannot open:File exists". So I copy all the unzipped files to var/run on the SD card. After I did it, the error shows unable to connect to system bus: Failed to connect to socket /var/run/dbus/system_bus_socket: Connection refused.
I found the the size of system_bus_socket is zero. What about your system_bus_socket ?
Rita_Wang
Hi wenjing,
The size of system_bus_socket is not zero on my ubuntu. I wonder how did you written images to SD card.  I recommend you to download by MFGTool, if error come you can seen clearly.
Best Regards
Dan
