Does i.MX6 FSL_USB_TEST_MODE support down stream of USB hub?
Question asked by Satoshi Shimoda on Mar 25, 2014
Latest reply on May 16, 2014 by igorpadykov
Hi community,
I have a question about i.MX6 Android BSP (jb4.2.2_1.0.0).
I tried USB test refer to https://community.freescale.com/docs/DOC-94460 with the following connection.
i.MX6D USB H1 --> USB Hub --> USB Device
In this case, USB Hub works fine, but USB Device did not work correctly.
Then, please see my question as below.
[Q]
Does the "FSL_USB_TEST_MODE" support down stream port of USB Hub as the above connectoin?
Satoshi Shimoda
